ZHIWHIS Shortwave Radio, Portable Weather Radios with 7 Backlight Colors and APP Control, AM FM VHF SW WB Receiver with Bluetooth, Radio Recording, 6 EQ Modes Rechargeable Flashlight SOS Alarm ZWS-787
Price: $45.77 - $64.99
(as of Apr 08, 2025 18:15:32 UTC – Details)
ZHIWHIS APP Control FM/VHF/AM/SW/WB Radio with Bluetooth, MP3 Player ZWS-787
This is a small shortwave radio. It might be small, but it’s able to receive AM/FM/VHF/SW/WB.
It truly will fit in your pocket, it also has flashlight, SOS alarm, Bluetooth, TF card player function.
If you had to take a radio with you that was lightweight and portable this is your ticket.
Tough little pocket size radio, that does it all!
USB connection function as an external speaker
USB-C Connection Function
After connecting the radio to the computer’s USB port by using the attached USB Type-c cable, you can use the unit as an external speaker of the computer and as a card reader of the TF card.
Radio Recording Status
Radio Recording
The portable radio have a record function, you can directly operate the device itself to record the current broadcast. Radio records to TF card.
You get FM (87-108MHz), VHF(30.0-199.975MHz) *FM modulation only, AM, SW (4.750-21.850MHz) , and weather band with NOAA emergency alert function.
Great sound from a small radio
Bluetooth5.0
Bluetooth5.0
Bluetooth 5.0 Reception Tech
The rechargeable radio supports Bluetooth audio, you can send audio from your phone or computer to the tiny but fine speaker.
So you can play your own music from Spotify or use it for watching movies, it has a much louder fuller sound than any phone speaker.
MP3 Player
MP3 Player
TF/ MicroSD Card Playback
The MP3 player is compatible with MP3/WAV/WMA/APE/FLAC music format, which can insert TF card that up to 256GB.
There are six sound effects (Natural, Popular, Rock, Jazz, Classic, Country) to choose from.
There are four repeat play modes (Repeat All, Repeat One, Repeat Folder, Random) to choose from.
7 Backlight Colors
The different backlight colors corresponding to each broadcast band.
ZWS-787 radio designs seven kinds of backlight colors which can provide users with different visual experience.
FM&VHF: Green / AM: Purple / SW: Yellow / WB: Red
Bluetooth: Blue / MicroSD: Light Blue
Clock display status: White
7 Backlight Colors-The different backlight colors corresponding to each broadcast band.
APP Remote Control(it can support Android and IOS)
You can download the app, for most functions, and control.
The app is really neat too, gives you all of the controls from volume to tuning, band select, EQ, etc.
App offers great info: Demodulation, Bandwith, SNR, RSSI, Vol.
The APP lets you program in text the name and description or anything you want. The app gives complete control of radio plus long tags (>300 chars) for 396 memory channels.
Package Included
Exquisite Package
1 x ZWS-787 Portable Shortwave Radio, 1 x 1000mAh battery(Built-in)
1 x Waterproof Storage Bag, 1 x External Antenna
1 x Earphones, 1 x Lanyard, 2 x English User Manual
1 x Exquisite Packing Box, 1 x USB Type-C Data Charging Cable(39.4in length)
ZWS-787 Portable Shortwave Radio Exquisite Package
Included External Antenna
Excellent Reception
The included external antenna is a 9.85 feet long wire that really improves the FM/VHF/SW reception.
Alarm Clock, Auto Power-on, Sleep Timer
10-120 minutes sleep time
It can put you to sleep, then shut down itself after a specific time set to your choice.
Flashlight & SOS Alarm
It supports emergency function and is an emergency product that can be used at home and outdoors.
Rechargeable long-life battery
Provides up to 13 hours of playtime on a fully charge, or up to 20 hours of use with headphones.
1 Included External Antenna 2 Sleep Timer 3 Flashlight 4 13 Hrs Play Time
Compared with similar radios, what improvements have been made to ZWS-787 products?
Support downloading APP to remotely control the radio.
It can be set up to 120 minutes sleep time.
You can directly operate the device to record the current broadcast without operating the APP application.
Supports manual deletion of saved channels.
Please tell me the specification of the ZWS-701 product?
– FM: 64-108 MHz, VHF: 30.0-199.975MHz, AM: 520-1710KHz, SW: 4.75-21.85MHz, WB: 162.40-162.55MHz
– Number of stored stations in the radio mode: 396(FM/VHF/AM/SW: 99 of each)
– Power: Built-in 1000mAh lithium battery
– Charging: DC 5V USB-C interface
Please tell me other specifications of ZWS-701 product?
– Dimensions: 92*53*26mm/ 3.6×2.1×1 inch, – Weight: 110g/0.24lb
– Bluetooth Edition: VER 5.0
– Support: MicroSD/TF card, up to 256GB, Support MP3/WAV/WMA/APE/FLAC format
– Built-in speaker: Ο†40mm/4Ξ©/3W, – Headphone Jack: 3.5mm
– FM Antenna: 13inches
How do I download the app?
– Android: Scan the QR code in the attached APP Instruction manual to download the app β€œRadio-C”.
If you can’t download it, please contact me to get the APK installation package.
– IOS: Go to β€œApp Store” and search β€œRadio-CT” to download the App.
Other? – This product is covered under After-sales for a period of 12 months from the date of retail purchase.
– This product had been strictly inspected before leaving the factory. If it has any quality issues, we will provide the service of 100% return or replacement.
– Tell us if you have any product problems, we promise to solve them as soon as possible.
ZHIWHIS PORTABLE RADIO
Band
FM, AM, SW, WB, VHF
FM, AM, SW, WB
FM, AM, SW, WB
FM, AM, Shortwave
FM Stereo
FM, AM
FM,AM,SW, CB, VHF,UHF, WX, AIR
Headphone Jack
βœ”
βœ”
βœ”
βœ”
βœ”
Power Source
Built-in 1000mAh Li-ion
1000MA BL-5C lithium battery
2 x AAA Battery
Built-in 500mAh Li-ion
Size & Weight
3.6*2.1*1 in, 0.24lb
4.7*3.1*0.9 in, 0.37 lb
3.14*1.1*0.78 in, 0.09 lb
3.3*1.8*0.5 in, 0.1 lb
4.37*2.36*0.8 in, 0.3 lb
Sound Output
3W Speaker, Headphone Jack
3W Speaker
3W Speaker
3W Speaker, Earphone Stereo
3.5MM Headphone Jack Stereo
Speaker, Headphone Jack Output
Features1
Bluetooth,Flashlight,Alarm,6EQ
Bluetooth,Support TF Card,6 EQ
BT, Support TF Card, Recorder
Digital Clock, Sleep Timer
SSB Shortwave, Sleep Timer
Features2
7 Backlight Colors,APP Control
Preset,Spectrum light,Analog
Preset,Sleep Timer,Alarm Clock
Digital Keyboard,Lyric Display
Preset Channels, DSP, LOCK
Temperature Display, Preset
Recommended For
Indoor, Travel, Hiking,Camping
Hiking, Camping,Picnic, Indoor
Indoor, Bedroom, Kitchen
Hiking, Indoor, Bedroom
Hiking, Travel, Camping, Boat
[7 Backlight Colors] – There are seven backlight colors, which change depending on the operation mode. The different backlight colors corresponding to each broadcast band.
[APP Remote Control] – There is an app that you can download to use together with this radio. It controls the unit over Bluetooth. The app is really neat too, gives you all of the controls from volume to tuning, band select, EQ, etc. App also offers great info: Demodulation, Bandwith, SNR, RSSI. It also lets you program in text the name and description for 396 memory channels.
[Radio Recording] – The shortwave radio have a record function, you can directly operate the device itself to record the current broadcast without operating the APP application. In addition, It uses a 1000MAH lithium battery which is charged through a USB-C jack. It is charged 4 hours for 13 hours using.
[Excellent Reception] – You get FM, VHF (30.0-199.975MHz), AM, SW (4.750-21.850MHz), and weather band with NOAA emergency alert function. If the built in 13” antenna isn’t enough, there is an additional 9.85 foot long wire antenna that you can clip onto the built-in antenna for added reception capabilities. The built-in antenna is made of high toughness material, which is not easy to break.
[Superb Sound] – The 3W high quality speaker is backed by a bass radiator and driven by a high quality amplifier. With the volume turned up it is quite loud and full with little to no distortion. It also has 6 equalization options, not only supports Bluetooth and MicroSD card playback mode, but also supports radio mode. You also can connect your favourite set of headphones for personal listening.
[Ultra-Portable] – The handy size of 3.6×2.1×1 in and weight of 0.24 lb, equipped with a waterproof storage bag and lanyard, make it easier to carry and store. It’s extremely compact, smaller than a deck of cards and will easily fit in a shirt pocket. This is perfectly sized for keeping in your glovebox, backpack, or tackle box to take fishing, camping, hiking or anywhere.
