ZHIWHIS Shortwave Radio, MP3 Player with Weather Radios Portable AM FM, Retro Bluetooth Speaker with 6 EQ Modes, Rechargeable Alarm Clock Receiver with Sleep Time and NOAA Alerts ZWS-701
Price: $38.77
(as of Mar 02, 2025 03:45:17 UTC – Details)
ZHIWHIS Bluetooth Speakers, Portable Radio MP3 PlayerZHIWHIS Bluetooth Speakers, Portable Radio MP3 Player
ZHIWHIS RADIOZHIWHIS RADIO
ZHIWHIS is a modern radio production company.
Our main business is Portable Radios, Shortwave Radios, Headset Radios, Weather Radios, FM Transmitter. We provide different types of radios for various scenarios.
ZHIWHIS is committed to providing our customers with the most cost-effective high-quality radio products.
We ALWAYS stand behind the quality in all our products.
BT Speaker, Shortwave Radio
Portable Radio
FM Receiver Radio
FM Headset Radios
[Superb Sound] – The audio is crisp and the bass is actually quite good since the speaker is one of those 40mm ones rated at 3 watts. With the volume turned up it is quite loud with little to no distortion.
[Military-style Design] – Inspired by military-spec equipment that combines elements of ammo boxes, camouflage, steering wheel, and armored vehicles, gives it a bold style with rugged quality. It uses a replaceable lithium battery which is charged through a USB-C jack.
[Novel Experience] – It will even work as a wireless speaker, and has several EQ settings available when used in that mode. It will also play MP3, WAV, or WMA music files from a micro SD card (up to 256 gb capacity), you can pick different folders, you can pick shuffle, play folder on repeat, Play song on repeat, play all songs.
[Excellent Reception] – You get FM (87-108MHz), MW (520-1710KHz), SW (4.750-21.850MHz) , and weather band (162.400-162.550MHz) with NOAA emergency alert function. It can be set to covers all the FM bands (64-108MHz) used internationally. The built in telescopic antenna is 11 inches tall and the included external antenna is a 9.84 feet long wire that really improves the FM/shortwaves reception.
[Simple Operation] – The Shortwave radio can store 114 stations and sets up two choose station โ€‹methods, including use the TUNE dial and press key. In addition, the volume is adjusted by knob, which is easy to operate. When you press the button, the orange backlight is convenient for night operation.
[Alarm Clock, Auto Power-on] – The radio has a digital clock so you can get the time at any time. Also, The clock radio can be set to automatically turn on or as an alarm clock radio(at the set time, then the radio will ring).
