Price: $199.99
(as of Mar 03, 2025 11:45:17 UTC – Details)
🔅【HD 1080p and Record Video】Advanced AIST Technology to Generate HD Images,Built-in 32G memory card for recording video.And You Can Play Video on Monitor.Making Your Receiving More Confident and Safe.
🔅【Multi-function View】This system support up to 4 cameras, it can be Freely Switched to Single View Dual View or Quad View(CH1/CH2/CH4). Dimension of the camera (without bracket): 2.95inch(L) * 2.36inch(H) * 1.85inch(W)
🔅【Night Vision and IP69 Waterproof】CCD Sensor for Rear Camera.Make the Night Vision Images More Clear and Stereoscopic.Accurately Identify Lawns, Lakes, and Stones even in the Dark.The Camera Outer Casing is Closed with a Metal Gel. Anti-fog and Waterproof.
🔅【Easy Installation and Wide Application】There is a Graphic Manual and Install Video in the Kit.12-24V DC Voltage Range From To Accomodate a Wide Variety of Large Vehicle as RV/Camper/Truck/5th Wheel Trailer/Bus/Van/Pickup.
🔅 Please note that the system transmits the camera image to the monitor via a wireless 2.4GHz signal. There is no cable between the camera and the monitor, but the camera and the monitor need power cord to get power and work, which saves yourself the trouble of charging and provide convenient and safe monitoring for your travels.
