Price: $10.69
(as of Mar 26, 2025 19:15:24 UTC – Details)
Product description:
* This is only a outdoor antenna which receive signal, would not generate any signal.
* Wide band 698-4000MHz compatible for 3G/4G/LTE/5G mobile signal booster.
* Durability and Waterproof, Outdoor use is supported, wider coverage.
* The 5 meter low loss cables keep coax lead cable as short as possible & weatherproof all outdoor connectors.
* The installation mast is not included.
* Not work as hdtv antenna or fm radio antenna.
* Please note the connector type before purchasing.
Easily Use:
1. Please check your Frequency before you buy it, because the antenna can only work on right frequency.
2. Outdoor antenna→Signal Booster→Indoor antenna, these three devices should be connected via coaxial cable(sold separately). The antenna itself doesn’t produce much gain.
3. Antenna Placed is the higher the better. Also, you should find somewhere outdoor where the signal is stable to install.
Product information:
Frequency Range: 698-4000MHz
Gain: 10-12dBi
VSWR: ≤2.0
Polarization Type: Vertical
Radiation: Omni
Maximum input power: 100W
Input lmpedance: 50 Ohms
Cover Material: PVC
Working Temperature: -40℃ ~ +60℃
Connector: SMA male
Cable length: 5 meters
Adapter Cable: SMA Female to Dual SMA Male with 16.5cm RG316 Cable
Use place: Outdoor
Package includs:1 x Antenna Kit; 1 x Adapter Cable;
[Antenna Connector & Cable]Cable Length: 5 meter; Antenna Connector:SMA Male; Adapter Cable: SMA Female to Dual SMA Male with 16.5cm RG316 Cable.
[Wide Compatible] The antenna with SMA Male Original Connector Compatible with 3G/4G/LTE/5G Mobile Router, Mobile Broadband Modem Hotspot, Cellular Gateway,CPE Router; Home Office Indoor Cell Phone Signal Booster Repeater, Vehicle Car Truck RV Bus Van Mobile Cellular Amplifier.Also Compatible with(when use Adapter Cable) 3G/4G/LTE/5G Mobile Hotspot, MiFi Router, Cellular Mobile Broadband Modem, Wireless CPE Router, USB Modem Dongle Adapter.
[Install Note] Please turn off the power of your deviceï¼›Please keep antenna as vertical as possibleï¼›Please install the antenna as high as possible to get a better signal.
[Help]If you are not sure whether it applies to your device, please contact us for help.You can also ask us questions in Customer questions & answers.
