YOLANESS Portable Power Station 500W 560Wh Solar Generator with 110V Pure Sine Wave AC Outlet for Outdoor Camping, RV and Home Use – Blue
Price: $899.99
(as of – Details)
2424
2424
YOLANESS Portable Power Station TB500
1. The YOLANESS Portable Power Station TB500 boasts a generous 560Wh capacity, ensuring reliable and ample power for outdoor adventures.
2. A constant output of 500W enables this power station to provide reliable power to a variety of outdoor devices, ideal for camping trips.
3. The use of high-quality, built-in lithium batteries ensures the TB500 is safe, long-lasting and durable, delivering consistent performance over time.
4. With 2 x 500W pure sine wave AC outlets, the TB500 provides a stable and clean power source for all your essential devices.
5. The Type-C PD 65W port delivers fast and efficient charging for all your USB-C enabled devices.
6. The versatile 13.6V/8A DC5521 output and car socket allow for powering a range of devices, including CPAP machines, mini fridges and more.
7. The DC7909 input port with a maximum input power of 120W supports the use of two solar panels in series, making it easy to charge and power on the go.
22
With 560Wh lithium batteries and a 500W inverter, the YOLANESS power station can power most of devices.
1111
147147
This solar power station is compatible with virtually all devices and will meet all your demands.
789789
FAQ
Q1: How long will the YOLANESS TB500 battery power station power my device?
A: The estimated working time can be calculated as follows: Working time (estimate) = 560Wh * 0.9 / Operating power of your device. (0.9 is the Conversion Rate). Please note that the duration of operation may vary depending on the specific device being used and that the data used in the estimation was gathered in a laboratory setting.
Q2: What devices can TB500 solar generator power?
A: The TB500 can charge devices that operate at 500 Watts or less through the AC output port.
Q3: Can the YOLANESS TB500 camping power station be charged while in use?
A: Yes, the TB500 supports pass-through charging, however, it may reduce the lifespan of the battery.
Q4: What type of solar panel is compatible with the YOLANESS TB500 camping battery generator?
A: Any 11-28V solar panel with a DC 7909 male connector can be used to charge the device.
Q5: How should I store and maintain the portable power station?
To preserve the battery lifespan:
1. Recharge the device to 100% after each use.
2. Recharge it to 100% every 3 months.
3. Turn off the power if the device will not be in use for an extended period of time.
✅Essential for the Great Outdoors: The YOLANESS solar power generator is an indispensable tool for those who enjoy camping and outdoor adventures. With 560Wh lithium batteries and a 500W inverter (peak 1000W), this power station is equipped to power a wide array of devices, including cameras, laptops, mini fridges, and CPAP machines, ensuring that you stay connected and comfortable no matter where life takes you.
✅Premium Quality and Durability: Constructed from high-quality materials including aluminum+ABS shell, large gauge wires, UL certified power cells, and well-soldered circuit boards, the solar generator is designed for exceptional safety and longevity.
✅Versatile Connectivity: With a range of 9 ports including 2 pure sine wave AC outlets, 2 DC ports, 3x18W USB-A ports, 65W USB-C port, and a vehicle-class outlet, this solar power station is compatible with a wide range of devices.
✅Multiple Safety Warranty: Built-in the Battery Management System (BMS) improves the battery’s safety level massively. The power generator’s comprehensive multi-protect safety system includes overcharge protection, short circuit protection, temperature control and more.
✅Our Promise: With an 18-month warranty and a 100% satisfaction guarantee, YOLANESS stands behind their product. If for any reason you are not satisfied with the solar generator, you can receive a full refund and a return label.
