Yoidesu 5 Inch Portable TV, 1080P ATSC Pocket Digital Car TV Analog TV with 1500mAh Rechargeable Battery, Support ATV USB TF Card Input FM Radio, ISDB T LED Mini TV for Car Camping, with Remot, Stand
Price: $77.56
(as of – Details)
5 inch Portable TV5 inch Portable TV
Yoidesu 5″ Portable Digital TV
This is a portable digital TV. You can insert a USB disk or memory card to the ports at the side and play the videos you download previously. The multimedia player with built-in high-performance speakers will deliver HD sound to your ears. It is made from ABS material, durable and lightweight, no much burden to your hands. There is a foldable holder at the back, you can put it on desktop and watch video. Or you can put it on a flat surface or fix it to wall to watch TV.
the Mini TV is equipped with a TV stand on the basis of the small screen, which is convenient for users to use.
this Portable TV is equipped with high sensitivity adjuster, which makes the signal receiving ability much better than before.
How to Use:
1. Turn on the power switch.
2. Turn on the TV, press the interface guide for the first time, select the country, language, and automatically search for channels.
3. After searching the station, you can watch it normally.
YoidesuYoidesu
Our store was founded on October 20, 2019, the name Yoidesu comes from ใ‚ˆใ„ใงใ™ in Japanese, which means excellent, smart and kind. Just as the original intention when our store was founded – Provide Customers with High-quality and Low-cost Products and the Best Quality Service. We have always insisted on the purpose of”customer-centric” and advanced towards the goal of “providing the best quality services and products”.
Package List: 1 x TV 1 x Manual 1 x Remote Control 1 x Antenna 1 x Charger 1 x Telescopic Antenna
5 inch Portable TV
ATSC HD TFT LED Pocket TV | 1080P | 1500mAh Rechargeable Battery
Specification:
Item Type: Portable Digital Television
Receiving Channel: ATV 48.25Mhz ~ 863.25Mhz
Digital TV VHF (50MHz ~ 230Mhz)
UHF of Digital TV (474Mhz ~ 862Mhz)
Display: Color TFT-LED
Audio Output: 2W (Maximum)
Battery Type: Lithium Battery
Screen Size: 16:09
Voltage: 110-220V
Battery Plug: U.S. Standard Resolution: 1920 x 1280 Remote Control Battery Mode: 2 x AAA section (not included) Applicable Country: Canada, United States, Mexico, El Salvador, Dominican Republic, Puerto Rico (U.S.), U.S. Virgin Islands. Interface: Antenna interface, USB interface, power switch, headphone jack, memory card slot, power interface.
SUPPORT: Small portable tv supports 1080p video, MKV, MOV, AVI, WMV, MP4, FLV, MPEG1 4, 1080P video MP3, video.
RECHARGEABLE: Portable TV LCD monitor is equipped with a 1500mAh, rechargeable lithium battery for outdoor use.
WITH TUNER: Portable tv with antenna has a high sensitivity tuner to enhance signal reception, support FM radio function.
WITH A STAND: 5 Inch Portable Digital TV has USB port, small memory card slot, play the content of U disk drive, and with a stand, easy to use.
