Yakry RV Backup Camera Plug and Play – No Delays 7 Inch HD 1080P Rear View Camera with IR Night Vision 2 Channels – Waterproof Reverse Camera for Truck Trailer Camper Tractor Y14
Price: $69.99 - $79.99
(as of Mar 28, 2025 05:00:36 UTC – Details)
3
Product Dimensions ‏ : ‎ 29 x 21 x 8 inches; 3.59 Pounds
Item model number ‏ : ‎ 8542135292
Date First Available ‏ : ‎ July 11, 2018
Manufacturer ‏ : ‎ iStrong
ASIN ‏ : ‎ B07DC4DM3N
Country of Origin ‏ : ‎ China
►【Wired Back up Camera, Stable Signal Transmission】 The wired reversing camera kit has more stable transmission and will not lose signal at any time. If your wireless backup camera is always intermittent and delayed, a wired camera is a reliable companion for every drive.
►【Clear Night Vision & 150 Degree Wide Viewing Angle】True IR night vision greatly enhances the image, and the camera works even with minimal light around, allowing you to identify objects in the dark. 150 degree wide viewing angle, good assistant for reversing and parking at night, and provides excellent clear images in rainy days.
►【Rear View Camera with Parking Guidelines & Image Flip】Reliable packing lines and image flip for fast and perfect reversing, even if you sometimes have trouble figuring out the steering, just switch to the “mirror” view on the monitor, making you at ease when reversing.
►【2nd Vehicle Backup Camera can be Added】The 7 Inch HD Monitor has capability to monitor two video inputs V1/V2, one license plate camera or standard camera can be added to the system. V2 video input will have priority (hd backup camera) for safety.
►【Warm Hint for Backup Camera System】 Bracket Adapter compatible Furrion pre-wired Bracket and Power outlet can be provided according your need. Trailer camera is connected to monitor direct by 66ft video cable. 1080P Monitor can be mounted on the dashboard or windshield.
►【3-Year Technical Support & Quality Warranty】Yakry provides Lifetime Technical Support, 3-Year Replacement Service, and 30-Day Money-Back Guarantee for each truck backup camera, please contact us if you have any questions.
