Wrenchfire Triple Jet Torch Lighter,Windproof Refillable Gas Lighter Adjustable Flame Intensity with Visible Gas Window Cigar Punch Cigar Rest,Black
Price: $16.99
(as of Feb 14, 2025 03:00:35 UTC – Details)
Why choose our lighter?
*Triple jet torch lighter,generates enough firepower to light up articles evenly
*Built with ceramic insulation burner,adjustable flame intensity makes it widely used for cooking,culinary,BBQ,hiking,mountainering,lighting up cigar,cigarette and so on.
*Visible gas window reminds you to refill with gas,much convenient.
*Windproof jet torch, the flame still works even under windy weather.
*Cigar punch cuts a perfect hole on the cigar.
Package includes 1x lighter
Note:The lighter is empty without butane gas due to air mail regulation,please fill with gas before using,thank you.
Windproof Jet Torch and Adjustable Flame Intensity:Adjust the flame intensity easily with a screwdriver from low to high and wind holes design increases the firepower,also it works even under wind condition.
Refillable Butane Gas and adjustable flame intensity: This lighter is recycle to use by refilling butane gas on the bottom tips, more environmental friendly than disposable lighters. Flame height can be adjusted to meet different needs of ignition,such as light up cigar/cigarettes ,culinary use,cooking,BBQ and other indoor or outdoor activities.
Professional Cigar Lighter: It is designed with visible gas window and cigar punch,cigar holder/rest. Visible gas window helps you to monitor the gas level and reminds you to refill.Cigar punch cuts a perfect hole on the cigar.
More Details: It includes 1x lighter with box(GAS IS NOT INCLUDED). Lighter size:93x32x22mm/3.66×1.25×0.86″;Weight:about 116g.Any question about the lighter or our service is welcomed to contact us,thank you.
