Wireless RVBackup Camera for RV Truck Trailer Camper Digital 3 Rear/Side View Cameras & HD 1080P 4 Splits 7″ Screen with Adapter for Furrion Pre-Wired Night Vision IP69 Waterproof 170° Wide View Angle
Price: $337.75
(as of Mar 21, 2025 12:30:29 UTC – Details)
7 inch Wireless backup camera with strong stable signal
Wireless backup cameraWireless backup camera
Wireless backup cameras have a strong signal and long signal distance. The strong signal ensures stable transmission of images and audio, eliminating interference and signal loss issues. The signal distance can reach up to 330ft, allowing users to observe the rear in real-time over a larger range, thereby enhancing driving safety. Additionally, wireless backup cameras have excellent signal penetration capabilities, enabling them to be used in complex environments with obstacles such as buildings and trees. This makes wireless backup cameras an ideal auxiliary tool, helping drivers better understand their surroundings and providing a convenient and safe reversing experience.
1080p wirelss backup camera system for Cars Truck Pickup Trailer Camper Bus RV 5th Wheel.
Douxury wireless backup cameraDouxury wireless backup camera
This backup camera features a 7-inch large screen with 1080p HD resolution for clear and detailed images. It uses digital wireless transmission technology, ensuring stable signal without the hassle of wires. The camera also has a recording function to capture important moments while driving. With touch buttons for easy operation and adjustment, it reduces wear on physical buttons. The quad-split display shows images from four cameras simultaneously, providing a comprehensive view of your surroundings. Additionally, you can add an extra camera to the system.
Wireless Backup Camera System with 4 Splits Screen
4 splts screen wireless backup camera4 splts screen wireless backup camera
The quad-split feature of the backup camera has several advantages: it simultaneously displays the images from four cameras, providing a comprehensive view; reduces blind spots and helps avoid overlooking obstacles; enhances reversing safety; and allows for better control of the reversing process, reducing operational errors. In summary, the quad-split feature makes the backup camera more comprehensive, safer, and more convenient.
Wireless Backup Camera easy to install
wireless backup camera easy to installwireless backup camera easy to install
This backup camera is easy to install as it only needs separate power connections for the camera and monitor. No wiring on the vehicle body is required, making the installation process simple and convenient. Just connect the camera and monitor to the power source. Even without professional skills, the installation is hassle-free. In summary, this backup camera is easy to install, needing only power connections for the camera and monitor, without complex wiring on the vehicle body.
170° wide angle douxury backup camera170° wide angle douxury backup camera
douxury mirror backup cameradouxury mirror backup camera
douxury backup cameradouxury backup camera
This camera features a 170-degree wide-angle lens, providing a broader field of view to help you better observe your surroundings and enhance driving safety.
Mirror and Flip
This backup camera can horizontally flip the image and display it on the screen, ensuring that it matches the actual situation. This helps you accurately judge direction and distance while reversing.
IP69 Waterproof Level
This backup camera is IP69 waterproof, ensuring excellent performance in extreme weather. It can provide clear images in heavy rain or high temperature, offering reliable visual assistance for reversing.
douxury backup camera with super night visiondouxury backup camera with super night vision
douxury backup camera with adjustable parking assist linedouxury backup camera with adjustable parking assist line
douxury backup camera 3 ways to install the monitor3 installation waysdouxury backup camera 3 ways to install the monitor3 installation ways
Super Night Vision
This backup camera has 18 infrared lights for excellent night vision. It provides clear black and white images in dark or low light conditions, ensuring reliable visual assistance for night reversing.
Parking Assist Line
The backup camera is equipped with adjustable parking lines that can be adjusted as needed. It provides accurate guidance lines to help you reverse and park with ease.
3 Ways to Install the Monitor
Our backup camera system includes butterfly and U-shaped brackets for installation on the dashboard. For easy installation on the windshield, you can use the suction cup bracket (not included).
Upgraded Digital Backup Camera: The signal can reach up to 825 feet in open areas and work within vehicle range up to 320 feet. The latest version of the digital signal wireless backup camera will send a powerful signal to the 1080p display. The signal can reach up to 825 feet in open areas and work within vehicle range up to 320 feet.
Touch Buttons & HD 1080P: Reduce the risk of monitor key, rv monitors are more durable, smoother and have a longer lifespan. 1080p HD images during the day, bright and clear images at night. More safer。
DVR Record Function: You can avoid a lot of traffic scams/thefts. The wireless rv rear view camera has a loop recording function. Compatible with RV car truck bus trailer camper semi truck and other types of vehicles.
IP69 Waterproof: with upgraded sealing technology, rv backup camera can reach IP69 waterproof. Adopt the latest all-metal sealing technology. It can withstand extreme weather, the lens does not get wet and does not fog
Easy to Install: You just need to power on the backup camera and the monitor respectively. Wiring and installation no longer affect your camper trailer.
【Quality Guarantee】30-Day Money-Back Guarantee and Lifetime Support, 365-Day Replacement Warranty, 24-Hour Online Customer Service. If you have any question or need any help, please contact us first, we’ll try our best for you.
