Wireless RV Backup Camera 7 Inch Monitor, Built-in Recorder Rear& Side Cam for Trailer Box Semi Truck Motorhome Camper Pickup, Digital 1080P AHD Rear Side View Cam w/ 260ft Satable Signal DVR System
Price: $199.99
(as of Mar 23, 2025 17:45:17 UTC – Details)
Great picture!
Product Dimensions ‏ : ‎ 11 x 8 x 3 inches; 4.12 Pounds
Item model number ‏ : ‎ CFW02
Date First Available ‏ : ‎ April 16, 2020
Manufacturer ‏ : ‎ Xroose
ASIN ‏ : ‎ B08PVDF78P
Country of Origin ‏ : ‎ China
【Extra Long Range Stable Operation Signal】AHD tech with extra long distance picture transmission, high rate and anti-interference. In the actual usage, refer to CM1 system, it wont happened delay within 100m/328ft after our testing on the open area. No interference, upgraded long range wireless signal can stay smooth and clear even car speeds up to 75Mile.(mentioned on the product description about the difference of AHD/HDCVI/HDTVI technology)
【Two Bracket & One Camera】One is dashboard bracket, the other is windshield mount which do not interfere with viewing while driving/ reversing. Switch ON/OFF for parking guidelines. Wireless 149 degree wide view backing up camera can be adjusted the installation angle to cover more dead spots.IP69 high rate waterproof let it work well no matter how long it rains. Anti foggy/snowy/water/high or low temperature. Xroose also supply more wireless camera separetely.
【Powerful Wireless Backup Camera System-CM2】Built-in 32GB SD card to storage video, the maximum storage of this rearview system up to 128GB. Keep recording at least 8 hours as well as seamless loop recording saving the cost of dash camera, help you record evidence once happened any accident. Wireless backing up camera can be adjusted the installation angle to cover more dead spots. IP69 high rate waterproof let it work well no matter how long it rains.
【2 Steps Installtion】Easy to install.Connect camera to reversing/running lights or other constant power, then connect the monitor to 12-24V cigarette lighter(2nd way: use the included kit to hardwired the monitor), no need to run wires to connect camera and monitor. The best choices of backup camera system for RV, Trailers, Trucks, Camper, Van, Motorhome, 5th wheel, Tractor, Pickup Truck, Semi Truck, Box Truck, Plow Truck, School Bus, Cargo Van, Boat, etc.
