Price: $269.99
(as of Apr 21, 2025 01:45:20 UTC – Details)
Wired Backup Camera System with 10.1’’ IPS Monitor for Truck RV Trailer Bus, Rear View Camera, with Side Front View Camera, 4 Split Screen, Super Waterproof, Night Vision, Easy Installation AHD1080P
【Back up Camera with Recording Function】 RV Backup camera system has recording function. it can also be connected to 12V-36 V range power source.In addition, this product supports 4 cameras for video recording at the same time, which allows you to record every pleasant trip you have made.
【Now, into the big screen world】 That’s the change that 10.1 inch big screen Back monitors bring to us! Because the display area is much larger than other 5-inch and 7-inch monitors, even if you adjust the screen to a 4-segment display, you can see it clearly and work more efficiently.
【Images Mirror Switch】 You can turn on the front or mirror display of each camera individually from the menu list. 【Guide Line ON/OFF/DIY】 You can set the guide line to always display, display after triggering, or turn off as needed.
【Easy for Installation】You only need to insert the cigarette lighter adapt into the cigarette lighter socket to supply power to the system and avoid the traditional complex power supply. You only need one cable to connect the monitor and camera, and then you can complete the installation after wiring.
【Customer Service】2 years warranty and life-time tech support.If you have any problems using the truck backup camera system, please contact us directly and we will be happy to help you.
