Price: $399.99 - $269.99
(as of Apr 17, 2025 10:45:23 UTC – Details)
Wired Backup Camera System with 10.1’’ IPS Monitor for Truck RV Bus Trailer,Touch Screen, with Side View Camera, 3 Camera, 4 Split Screen, IP68 Waterproof, Night Vision, Easy Installation,AHD 1080P
【AHD Backup Camera for truck】Make the installation of backup camera for truk/RV more diverse! All 3 Backup Cameras have night vision. At the same time, all of them use AHD high-definition technology to achieve 1080P high-definition picture quality.
【2.5D full touch screen】On this latest version, we use a 10.1 inch full touch screen with a whole 2.5D IPS panel. All physical keys except the power button are removed, and the overall design is simple, symmetrical and modern.
【Rear View Camera System】 That’s the change that 10.1 inch big screen Back monitors bring to us! Because the display area is much larger than other 5-inch and 7-inch monitors, even if you adjust the screen to a 4-segment display, you can see it clearly and work more efficiently.
【Recording and Playback】Truck Backup camera system has DVR recording function. it can also be connected to 12V-36 V range power source.In addition, this product supports 4 cameras for video recording at the same time, which allows you to record every pleasant trip you have made.
【Easy for Installation】 You only need to insert the cigarette lighter adapt into the cigarette lighter socket to supply power to the system and avoid the traditional complex power supply. You only need one cable to connect the monitor and camera, and then you can complete the installation after wiring.
【Customer Service】2 years warranty and life-time tech support.If you have any problems using the truck backup camera system, please contact us directly and we will be happy to help you.
