Windshield Car Phone Holder Mount Dashboard/Suction Cup/Window, 13″ Phone Holder for Car Dashboard with Super Sticky Gel Pad, Truck Cell Phone Holder for Car, Compatible with Thick Case & Large Phone
Price: $16.99 - $15.29
(as of Apr 09, 2025 18:00:38 UTC – Details)
👍Wider Bottom Tray: Windshield phone holder for car, features a wider bottom tray to provide larger space to plug the charging cable, which gives support to long-time navigation and radio on the road.
👍Thick Phone Case Friendly: The phone clamp of this windshield phone mount can open up to 92mm, which is suitable for 4.7-7 inches smartphone. Compatible with iphone 14/13/12 pro max mini, Samsung, LG and more. Please noted, phone case must thinner than 17mm, not fit for pop socket; phone ring holder, etc
💪Strong Suction Cup: Equipped with strong sticky gel pad, the car cell phone mount can withstand the temperature and load test in high quality. Note: If the suction cup loses its grip, wash it with warm water, then air dry to restore its adsorption.
👍One-Hand Operation: This cell phone car mounts designing with a back release button, which is easy to clamp and release. It is padded with striped silicone to protect your phone from scratching or dropping off.
NOTE 1: NEVER USE THE EXTRA DASHBOARD PAD FOR WINDSHIELD/GLASS/WINDOW MOUNTING.
NOTE 2: FOR DASHBOARD, PLEASE USE THE INCLUDED DASHBOARD PAD TO STICK ON THE FLAT SURFACE, NOT FOR CURVE SURFACE.
NOTE 3: YOU CAN USE DENTAL FLOSS OR PLASTIC SHOVEL TO SHAVE IT OFF FROM THE DASHBOARD SURFACE IF NECESSARY.
