Price: $17.89
(as of Apr 01, 2025 18:15:20 UTC – Details)
Specification:
Item Type: 4G WiFi Router
Material: ABS
Model: H806
Color: Black
Type: Plug in Card
Card Slot: Standard SIM Card
Battery Type: Built in 2100mAh Lithium Battery (included)
4G LTE Band: B1 B3 B5 B40
3G UMTS WCDMA: B1
WIFI: Support 802.11 b g n
Sharing: 10 Users
Package List:1 x 4G WiFi Router1 x Charging Cable1 x Manual
Note:Please check whether there is a partition sticker at the built‑in battery interface before powering on, if there is, please tear it off and power on, otherwise it cannot be powered on.
SEVERAL LIFETIMES: This portable WiFi hotspot has a built-in rechargeable battery that provides up to 8 hours of continuous internet usage. Stay connected throughout your car trip or outdoor adventure without worrying about running out of power.
COMPACT AND PORTABLE: Designed for travel, this WiFi hotspot is lightweight and small enough to fit in your pocket or bag. Stay connected wherever you go and enjoy high-speed Internet access anytime, anywhere.
ACCESSIBLE TO USE: Simply insert your SIM card into this device and turn it on to create a WiFi network. Connect your device and start browsing immediately. No complicated setup or installation required.
FUNCTIONAL DEVICE: This portable WiFi hotspot can not only surf the web, but can also be used as a card reader, allowing you to transfer files between devices with ease. It is a versatile and convenient tool for outdoor traveling.
