Price: $47.99 - $35.99
(as of Mar 07, 2025 23:15:17 UTC – Details)
【Power Bank Phone Charger】Compared with other emergency radio on the market, this 𝗽𝗼𝗿𝘁𝗮𝗯𝗹𝗲 𝘄𝗲𝗮𝘁𝗵𝗲𝗿 𝗿𝗮𝗱𝗶𝗼 built-in 5000 large-capacity rechargeable battery, when we are trapped in an emergency or our cellphone runs out of power, simply plug your phone or other small electronics into the USB port of this emergency kit for some extra power. Works with most USB powered devices, this survival gear could provide enough emergency power for important calls.
【5-Way Power Sources】This emergency solar 𝗵𝗮𝗻𝗱 𝗰𝗿𝗮𝗻𝗸 𝗿𝗮𝗱𝗶𝗼 with multiple power backup options is the best value for survival radio in this market. 5 power sources – 5000 Large Capacity Built-in rechargeable battery, solar, crank, 5V USB Input, 3*aaa battery. No matter what emergency you’re in, it never runs out of electricity!
【Camping Flashlight & Reading Lamp】It’s a smart choice to have this rechargeable 𝗰𝗿𝗮𝗻𝗸 𝗿𝗮𝗱𝗶𝗼 no matter for indoor or outdoor usage. Provides a 3W camping flashlight and 2.5W reading light, this battery operated radio is designed to light up your darkness when emergencies or bug out, flashlights for emergencies, emergency lights for home power failure.
【AM FM Shortwave Radio with Earphone Jack】Added a 3.5mm headphone jack and adjustable antenna, this 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝗳𝗹𝗮𝘀𝗵𝗹𝗶𝗴𝗵𝘁 𝗿𝗮𝗱𝗶𝗼 helps you to enjoy the AM/FM/SW radio with crystal sound and good signal. The big tuning knob makes it easier to tune into your favorite channel manually. The dimension of this portable 𝗮𝗺 𝗳𝗺 𝗿𝗮𝗱𝗶𝗼 is 6.69 x 3.74 x 2.36 inches and weight 1LB, which is surprisingly small and light to carry around.
【Loud SOS Alarm with Red light】Our 𝘄𝗮𝘁𝗲𝗿𝗽𝗿𝗼𝗼𝗳 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝘄𝗲𝗮𝘁𝗵𝗲𝗿 𝗮𝗹𝗲𝗿𝘁 𝗿𝗮𝗱𝗶𝗼 with versatile functions, a necessary prepper survival tool! When you are in an emergency or need help, you can turn on the flashing red SOS light and alert sound, this portable emergency radio will alarm loudly, and the red light flash meanwhile, which helps you easily get the attention of others.
