Waveform MIMO 4×4 Panel Antenna Kit for 4G & 5G Cellular Hotspots, Routers, & Gateways | T-Mobile 5G Home Internet, Verizon, AT&T Cell Signal Booster | Antenna Only
Price: $299.99
(as of Mar 06, 2025 01:45:21 UTC – Details)
If your LTE or 5G router supports 4×4 MIMO external antennas, and you’re looking to get the absolute best data rates, using a 4×4 MIMO external antenna is often the best option. Our 4×4 MIMO Panel antenna offers up to 9 dBi gain between 1710 and 2700 MHz, and 6 dBi gain between 600 MHz and 900 MHz.
ANTENNA ONLY – Pair this antenna with your own coaxial cables and antenna mount to connect it to your router or gateway. Or choose to purchase our Complete Kit that comes packaged with everything you need to get set up.
T-MOBILE 5G HOME INTERNET SUPPORT – Detailed guides for connecting to every TMHI gateway, including the Nokia 5G21, Arcadyan KVD21, and Sercomm Fast 56WW Gateways.
NETGEAR, PEPLINK, CRADLEPOINT, MOFI, AND MORE – Our 4×4 antennas work with AT&T, Verizon, T-Mobile, 4G LTE or 5G, and almost any modem and router manufacturer. As long as there’s a way to connect external antenna ports, our MIMO antennas can help you get dramatically faster Internet connectivity.
ULTRA HIGH PERFORMANCE 4×4 MIMO FOR OPTIMAL 5G – Get dramatically faster 5G data rates than any traditional cell signal booster, repeater, or amplifier. With full 4×4 MIMO support and up to 9 dBi gain from 600 to 6000 MHz, the Waveform 4×4 Panel delivers the fastest 4G and 5G data rates possible to any device with antenna ports.
