Walkie Talkies – GOCOM G600 FRS Two Way Radio for Adults 2W Long Range Walkie Talkie Rechargeable, VOX Scan, NOAA & Weather Alerts, LED Lamplight 2 Pack Hand held radios
Price: $20.99
(as of Dec 12, 2024 18:30:27 UTC – Details)
200
Product Dimensions ‏ : ‎ 2.17 x 1.57 x 7.09 inches; 3.53 Ounces
Item model number ‏ : ‎ G600
Batteries ‏ : ‎ 6 AA batteries required. (included)
Date First Available ‏ : ‎ August 29, 2019
Manufacturer ‏ : ‎ GOCOM
ASIN ‏ : ‎ B07X26191X
Country of Origin ‏ : ‎ China
【NOAA Weather Scan + Alert】- NOAA weather walkie talkies scan adults walkie talkies will automatically scan through 11 available weather band channels and locks onto the strongest weather channel to alert you of severe weather updates.Weather Alert will sound an alarm and display at LCD quickly when it receive 1050Hz weather alarm,it indicating it is a risk of severe weather in your area.
【22 Channels 2 Way Radios】- GOCOM walkie talkies feature 22 (Family Radio Service) channels and 121 CTCSS PRIVACY CODES system which gives you up to 2,662 combinations options to help block other conversations, along with channel receive to check for activity.
【1200mAh Ni-MH Rechargeable Battery】3 X 1200mAh AA NiMH battery supports normal work use;LCD screen and big keyboard is perfect for adults and beginners; Dual watch allow you to set up two channels and enable you not miss any call;
【Anything else?】 -Of course, the most important thing is that you will receive professional technical support from the product development team and GOCOM exclusive customer service on standby at any time to ensure that any questions you have can be solved online 24 hours, assurance to dismiss your worries before/after purchase. looking forward your message.
