Price: $1,099.99
(as of Feb 07, 2025 04:00:32 UTC – Details)
Wattage :
1500 watts
【Multiple Charging Methods】VTOMAN Jump 1500X power station has 2x DC5521(5.5mm*2.1mm) input ports that supports 200W max input power. When charging with 2x VTOMAN 100W solar panels(Included in packaging), Jump 1500X can be fully recharged within 6-10 hours(under full sunlight). Except charging by solar panel, Jump 1500X power station can be also recharged by wall charger(about 4-5 hrs to full) and 12 car outlet(about 6-10 hrs to full) .
【22% High Efficiency Solar Charging & Wide Compatibility】 VTOMAN foldable 18V/100W solar panel features 22% high conversion rate that can convert solar energy into electricity power more effectively than traditional panels. VTOMAN 100W panel is built-in 1x DC5521 output connector, 1x USB-A port(24W Max) and 1x Type-C port(45W Max), besides it also comes with 10 DC connectors of different size, which makes VTOMAN 100W panel compactible with most power stations and electronic devices.
【Pass Through Charging】VTOMAN Jump 1500X supports pass through charging, which enables you to use the output ports while charging the power stating by solar panel / AC charger / car charger. Also VTOMAN 1500X power station features a complete output ports including 3*110V/1500W AC outlets, 2*Regulated 12V/10A DC5521 output ports, 1*Regulated 12V/10A car cigarette lihter ports, 4*USB-A and 2*TYPE-C PD 100W output ports, which can charge up to 12 devices simultaneously.
【Expandable Capacity & Long-lasting LiFePO4】Jump 1000 LiFePO4 power station can expand its capacity from 1408Wh to 2956Wh with Jump 1500 expansion battery(Sold separately) when you feel the capacity is not enough. Also the LiFePO4 cell inside Vtoman power station features 3,000 full cycles of lifespan before going down to 80% of its original capacity.
【1500W Constant-Power Supply】VTOMAN Jump 1500X battery generator can provide rated 1500W pure sine wave of AC power(Surge 3000W). In addition to powering devices below rated 1500 watts like most power stations do, Jump 1500X can also output constant 1500W power when powering over 1500W equipment instead of disconnecting the output. It provides an emergency solution when powering appliances over 1500W, such as water heaters.
【Regulated 12V DC Output & Multiple USB ports】VTOMAN 1500W battery station has 2x 12V/10A DC5521 output ports and 1x 12V/10A car cigarette lighter port(total 120W Max), perfect for powering device supports 12V DC input, such as car refrigerators, CPAP machines, portable tire inflator, etc. Also Jump 1500X has 2* PD 100W Type-C(USB-C) ports and 4* USB-A output ports(18W Max), great for powering electronics sush as smartphones, tablets, etc.
【Multiple Uses】VTOMAN power station helps to improve your quality of life in many ways. It works as a great emergency backup power if you live in a residential area that’s prone to frequent blackouts, a region that’s expecially vulnerable to hurricane, snowstorms, mountain fires, flood, volcanoes, drought, etc, then VTOMAN power station will be a wise investment for your home. Also VTOMAN power station provides much convenience on camping, RVs, family road trips, vehicle survival, etc.
【What’s In The Box】1*Jump 1500X portable power station, 2*100W foldable solar panels, 1*AC charger, 1*Car charging cable, 2*USB cables, 10*DC connectors, 1*User manuals.
【24-Month Warranty】VTOMAN attaches great importance to customer experience and provides 24 month warranty for VTOMAN power stations. Please feel free to contact us for any questions, we’ll usually reply within 12 hours.
