VTOMAN Jump 1500X Portable Power Station 1500W, 828Wh LiFePO4 Battery Powered Generator with Expandable Capacity, 3x Pure Sine Wave 1500W AC Outlets (3000W Peak), 2x 100W USB-C, 3x Regulated 12V DC
Price: $799.99 - $569.99
(as of Apr 01, 2025 20:45:19 UTC – Details)
Vtoman Jump 1500XVtoman Jump 1500X
HIGHLIGHTS For VTOMAN Jump 1500X Portable Power Station – 1500W | 828Wh
1. Features 3x110V/1500W pure sine wave AC outlets, total 1500 watts(Surge 3000W).
2. Built-in long-lasting and durable LiFePO4 cell with up to 3,000 cycles of lifespan(To 80% of its original capacity).
3. Large capacity of 828Wh can be expanded to 2376Wh with VTOMAN Extra Battery(Sold separately).
4. 1500W constant-power supply for powering over 1500W appliances.
5. Dual PD 100W Type-C fast-charging output for powering MacBook, smartphones,etc.
6. Regulated 12V/10A DC5521(5.5mm*2.1mm) output and car cigarette lighter output great for powering car refrigerators, CPAP machines, portable tire inflators, car vacuum cleaners, etc.
7. Dual DC input ports with a max input power of 200W, supports charging with two solar panel in series.
LIFEBMS SYSTEM & LIFEPO4 BATTERYLIFEBMS SYSTEM & LIFEPO4 BATTERY
LIFEBMS is a battery management system by VTOMAN dedicated to improving battery safety and stability. It integrates up to 10 batterry protection modes, including short-circuit protection, over-current protection, over-voltage protection, etc. Also thanks to the built-in LiFePO4 cell, the battery safety and battery life of VTOMAN power stations have been further improved, which provides you a safe charging and long-term use experience.
PD 100W FAST CHARGEPD 100W FAST CHARGE
VTOMAN Jump1500X power station is equipped with 2*PD 100W Type-C outputs and 4*USB-A outputs, enough to power your smartphones, tablets, laptops and other electric devices at the same time.
RECHARGE WITH SOLAR PANELRECHARGE WITH SOLAR PANEL
Jump 1500X features 2 DC input ports (specification:5.5mm*2.1mm) with a max input power of 200W(The input for single DC port is also maximum 200W). It supports charging by wall charger, solar panels and car charger. When charging by solar panel, it supports charging with two solar panel in series. You can charge it with two 100W solar panels, also you can charge with one 200W solar panel.
MULTIPLE USESMULTIPLE USES
— FAQs —
Q: What’s the difference between Vtoman Jump 1500X and Jump 1500 power station?
A: The only difference between Jump 1500X and Jump 1500 is that the capacity of Jump 1500X is 828Wh while Jump 1500 is 1548Wh. Other than that, other feature is the same.
Q: How does the 1500W Constant-Power feature work?
A: When the operating power of the device connected to the AC outlet exceeds the 1500W rated power of Jump 1500X power station, Jump1500X will not automatically disconnect the AC output, but will keep output a constant power of 1500W for your device. However, it is not suitable for all appliances, and some appliances with strict voltage requirements may not work properly.
Q: Is the DC output regulated 12V?
A: Yes, Jump 1500X is built-in 2*DC5521 output and 1*Car cigarette lighter output, all of them are regulated 12V/10A.
Q: Does it support by-pass charging?
A: Yes, Jump 1500X supports by-passing charging. You can use the output function of the power station while getting charged.
Q: What kind of solar panel does Jump 1500X power station support?
A: The solar panel needs to meet following requirements:
1) The open circuit voltage is between 12-30V;
2) The solar panel features a DC5521(5.5mm*2.1mm) connector. If it doesn’t have that, you can convert it to DC5521 as well.
Q: Do I need to purchase an extra MPPT controller to connect the power station with solar panel when charging by solar panel?
A: No, you don’t need to do that, since all Vtoman power stations are built in MPPT feature.
Battery Type
LiFePO4 LiFePO4 LiFePO4 LiFePO4 LiFePO4
Battery Capacity
299Wh 1408Wh 828Wh 1548Wh 1548Wh
Expandable To
939Wh 2956Wh 2376Wh 3096Wh
AC Output
2*110V/600W (Surge 1200W) 3*110V/1000W (Surge 2000W) 3*110V/1500W (Surge 3000W) 3*110V/1800W (Surge 3600W)
USB-A Output
3*USB-A Ports 4*USB-A Ports 4*USB-A Ports 4*USB-A Ports
Type-C Output
1*PD 60W 2*PD 100W 2*PD 100W 2*PD 100W
DC Output
2*DC5521+1*Car Socket (12V/10A) 2*DC5521+1*Car Socket (12V/10A) 2*DC5521+1*Car Socket (12V/10A) 2*DC5521+1*Car Socket (12V/10A)
DC Input
1*DC5521 Input(65W Max) 2*DC5521 Input(200W Max) 2*DC5521 Input(200W Max) 2*DC5521 Input(200W Max)
Constant-Power
600W 1000W 1500W 1800W
LED Flashlight
【Capacity Expandable to 2376Wh】VTOMAN Jump1500X portable power generator has a large capacity of 828Wh, and the capacity can be expanded from 828Wh to 2376Wh with VTOMAN Jump 1500 Extra Battery (Sold separately) to provide you more juice for daily power needs. Besides, the built-in premium LiFePO4 battery features 3,000 cycles of lifespan before down to 80% of its original capacity, which can satisfy both your daily needs and long-term use purpose.
【1500W Constant-Power Power Station】VTOMAN Jump 1500X power station is rated to provide a pure sine wave 1500W load capacity(Surge 3000W). In addition to being able to power devices below rated 1500 watts like most power stations do, Jump 1500X will also output 1500W constant-power when powering over 1500W appliances instead of turning off its output. It provides you an alternative emergency solution when powering appliances over 1500W, such as water heaters, space heaters, ovens, etc.
【Dual PD 100W Type-C Output】VTOMAN Jump 1500X power station features multiple USB output ports, including 4* USB-A ports and 2* Type-C(USB-C) ports. The Type-C ports can provide a fast charge of 100 Watt Max for your electric devices, perfect for laptop office workers; the USB-A ports include a QC 3.0 fast charge port that can output 18W max, great for powering smart-phones, tablet, etc.
【Charging Up To 12 Devices Simultaneously】VTOMAN 1500W power station has a complete output ports including 3*110V/1500W AC Outlets, 2*Regulated 12V/10A DC5521 Output, 1*Regulated 12V/10A Car Port, 4*USB-A Output and 2*TYPE-C PD100W Output. It can charge up to 12 devices simultaneously, enough to power most of your electric devices and save your space on wall outlet! Jump1500X also supports pass through charging, which enables you to use its output function while it gets charged.
【Regulated 12V DC Output】VTOMAN 1500W battery power station features 2x DC5521 output ports(12V/10A, total 120W Max) and 1x car cigarette lighter port(12V/10A, 120W Max). All of them are regulated 12V output with a max output power of 120W in total. The DC ports are suitable for powering equipment supports 12V DC input, such as car refrigerators, CPAP machines, portable tire inflator, etc.
【Recharge to 80% Within 4 Hrs】VTOMAN Jump1500X power station features 2x DC5521(5.5mm*2.1mm) input ports that supports 200W Max input power in total. It can be recharged by three ways: 1)Recharging by wall charger(Included): about 4.5 hours to full; 2)Recharging by 12V car outlet(Car charger included): about 7 hours to full; 3)Recharging by 200W solar panels: about 6-9 hours to full.
