Price: $649.99
(as of Apr 17, 2025 11:00:35 UTC – Details)
VTOMAN Jump 1000 Portable Power Station with Extra Battery, 1000W/2956Wh Durable LiFePO4 Power Station with 1000W Constant-Power, Regulated 12V DC, PD 100W Type-C for Home Backup & RV/Van Camping
【SuperSafe LIFEBMS Power Station】VTOMAN battery power stations are built-in a super safe LIFEBMS battery management system that provides up to 10 battery protections for safe charging, including over-voltage protection, over-current protection, over-charge protection, over-discharge protection, etc. Also thanks to the built-in LiFePO4, Vtoman power station is more heat-resistant and safer than most NCM batteries.
【1000W Constant-Power Supply】VTOMAN Jump 1000 power station can provide pure sine wave 1000 watts of rated AC power(Surge 2000W). In addition to powering devices below rated 1000 watts like most power stations do, Jump 1000 can also provide constant 1000W power when powering over 1000W appliances instead of turning off the output. It provides you an emergency solution when powering appliances over 1000W, such as water heaters, space heaters, ovens, etc.
【Pass Through Charging】VTOMAN 1000 power station features 12 output ports including 3*110V/1000W AC outlets, 2*Regulated 12V/10A DC5521 output ports, 1*Regulated 12V/10A car cigarette lihter ports, 4*USB-A and 2*TYPE-C PD100W output ports. It supports pass through charging, which enables you to use the output ports while the power station gets charged. It can charge up to 12 devices simultaneously, enough to power most of your electric devices and save the space on wall!
【Regulated 12V DC Output】VTOMAN 1000W battery powered generator has 2x 12V/10A DC5521 output ports and 1x 12V/10A car cigarette lighter port(total 120W Max). All the DC output is with regulated 12V voltage, which is perfect for powering device and equipment that support charging by 12V DC input, such as car refrigerators, CPAP machines, portable tire inflator, etc.
【Dual PD 100W Type-C Output】PD 100W Type-C port is great for powering laptops. VTOMAN Jump 1000 is equipped with two PD 100W Type-C(USB-C) ports(total 200W) and four USB-A output ports. The USB-A ports also include a QC 3.0 fast charge port that can output 18W max, suitable for powering electric device sush as smartphones, tablets, etc.
【HOW TO RECHARGE】To charge the expansion battery, first connect Vtoman expansion battery to Jump 1000 power station via the CP3500 cable coming in the packaging; Then connect the AC Adapter & Car Charger & Solar Panels to Jump 1000 power station to recharge the expansion battery.
