Price: $149.99
(as of Apr 19, 2025 00:15:18 UTC – Details)
[ PORTABLE GARDEN SINK ]
▶Flexible wheels, detachable washbasin and stand, portable and easy to carry
▶With pedal design, can be used independently and cooperated with toilet or water tank
▶Equip with faucet and garden pipe joint, it can connect with garden pipe
▶Easy to assemble and disassemble, no tools required
Specifications:
1. Material: HDPE
2. Color: White
3. Unfolding Dimensions: (20.08 x 13.19 x 41.34)"
4. Wash Basin Size: (12.8 x 9.45 x 32.68)"(L x W x H)
5. Water Tank Size: (20.08 x 13.19)"
6. Water Tank Capacity: 5 Gallon
7. Hand Sanitizer Capacity: 3.5 L
8. Wheel Diameter: 1.77"
9. Weight: 8.16lbs
Package Included:
1 x Wash Basin
1 x Vertical Column
1 x Water Tank
1 x Hand Sanitizer
1 x Faucet
1 x Pipeline System
1 x Lower Water Pipe
1 x Garden Pipe Joint
[ PORTABLE CAMPING TOILET ]
▶ No External Water or Power Connections Required
▶ Waste Holding Tank Capacity: 5.3 Gallon/ 20L
▶ Fresh Water Tank Capacity: 3 Gallon/ 12L
▶ Flush Pump Type: Piston Pump
▶ Material: HDPE
Note:
– Close the lid before flushing.
– Release the air pressure before emptying by pressing the orange button.
– The sealing slide valve shall be closed in transportation, only when using shall it be opened.
Package Included:
-Portable toilet x 1
-Foldable carrying bag x 1
-Manual x 1
✔ [WATER FLUSHING]: Sink – Foot pump supports a stream of water with manually controlled switch. No plumbing required when used in garden connected with garden pipe. Toilet – Piston pump flushes the bowl with fresh water. T-type 3-way flushing removes the waste easier.
✔ [EXTRA-LARGE CAPACITY]: Sink – 5 gallon self-contained tank provides fresh water for washing hands and food. Made of eco-friendly food grade material, drinking water is allowed for storage. Toilet – 3 gallon flushing tank and 5.3 gallon waste tank; provide 95 to 98 times effective flushes in a flat state; allows to empty or refill it less often. Both can be supported by extra water tank.
✔[EASIER-TO-EMPTY]: Toilet – Slippery surface of the bowl refuses attachment of waste and prevent you from washing. Rotating pour spout allows you to dump it quickly without splashing. There’s a vent for release the bottom pressure; a level indicator for showing the inner waste amount. When the indicator turns red, it reminds you of the time to empty the waste tank.
✔ [ODORLESS & LEAK-PROOF]: Made of high density polyethylene, it features anti-leakage and anti-crackable. Sealing value prevents the waste from leaking and giving off smell. Liquid chemicals can be put into fresh water tank for aromatic air.
