VANMASS TOP Car Phone Holder [Military-Grade Suction & Vent Clip] Cell Phone Mount for Car Dashboard Windshield Vent, Truck Automobile Cradles Dash Stand Bracket for iPhone 14 Pro Max 13 12 11 Android
Price: $39.99 - $24.64
(as of Mar 13, 2025 15:00:34 UTC – Details)
【Larger Suction Cup, 2023 Strongest Suction】The diameter of the suction cup has been increased from 2.5in to 2.8in, and the PU adhesive has been applied to increase the suction power by 44%. Over 60 pounds of suction means even the heaviest phones are secure on bumpy roads. The suction cup is easy to remove and can be washed clean and reused (Note: NEW upgraded suction cup can be directly adsorbed to dash without pad!)
【Multi-Function Phone Stand for Dashboard / Windshield / Vent】Are you not sure which installation would best suit your vehicle? No problem the unit is extremely flexible!!! Dashboard, Windshield even air vent, all places work perfectly!
【2023 Longer & Firmer Hook Clip – Fit 99% vent】Its innovative hooked construction perfectly solves the shortcomings of the previous generation air vent clips which were prone to loosening! Maximum hook length increased by 57%, compatible with 99% Vertical / Horizontal vent. Longer build reduces obstruction of air flowing out of vent
【High-end = Quality Materials + Grandmaster Design】VANMASS car phone mount made of PC+ABS material has passed 4 environmental reliability tests and has a temperature resistance range of -40℉ to 194℉, it is also highly resistant to UV rays (Ensuring reliability even in the sun), and the telescopic pole uses a reinforced sliding rail structure to greatly reduce wobbling during driving. This suction phone cradle obtained CP65 / REACH / RoHS safety certifications
【Smoother “One-Click Release” & Perfect Protection】 You can easily place or remove the phone with one hand. After 7 structural reliability tests, we have upgraded the internal parts of the phone holder to improve the experience of using the”One-Click Release” function, which is smoother and more reliable. We also have used a more flexible silicone arm to hold your phone more securely and prevent it from being scratched by plastic
【Free Angle Adjustment】The long arm telescopic pole offers 4.1in~5.8in length adjustment and 270° angle adjustment, while the back of the phone holder has a 360° rotatable ball, these flexible parts allow you to use your phone at the most comfortable angle
【Sturdy Hold All Phone from 4 to 7 inch】To adapt to different phones and cases, VANMASS was the first to invent adjustable side clamps and feet. We have also designed a non-slip fingerprint area on the side clamps so that you can hold your phone more easily with one hand. This mount is compatible with all mobile phones between 4 and 7 inch, such as iPhone 14 Pro Max 13 12 11 XR X 8 7 SE mini, Samsung Galaxy S23 S22 S21 A53 A22, Google Pixel, Xiaomi, Motorola, OnePlus, OPPO, etc
