USB WiFi Router, 4G LTE USB WiFi Router Mobile Hotspot Portable Travel Mini Pocket Wireless Network Smart Router Plug and Play for Car Outdoor Use(With WIFI function)
Price: $29.90
(as of – Details)
Specification:
Style: With WIFI, Without WIFI (optional)
Category: Smart Router
Scope: Business Itinerary
Working frequency band: LTE-FDD: B1/B3/B5
Radio standard: IEEE 802.11b
Firewall Function: Support Firewall
Safety standard: ic
System: FDD-LTE
WiFi Frequency: 2.4G
WiFi protocol: 802.11b/g/n
Chip: Qualcomm
Network Type: FDD-LTE, WCDMA/DC-HSPA+
External interface: USB 2.1, standard 6-pin SIM card interface
SIM Card: Standard SIM Card Size: 15×25mm (Not Included)
Frequency Response: FDD: B1/B3/B5
WCDMA: 2100MHz
Rate: UL50M/DL100Mbps
Supported operating systems: 32/64 bit: For Win 2000/2003/XP/Vista/7/10, for OS 10.4 or higher, for Linux
Input: 5V/1A
Power Consumption: Less than 2W
Wireless Security Mode: Open, WPA-PSK, WPA2-PSK
Size: Approx. 9.7 * 3.5 * 1.2 cm/ 3.8 * 1.4 * 0.5 inch Package Weight: Approx. 53 g
Package list:
1 * 4G WiFi Router
1 * English Manual
Note:
1. This product requires a card, which is not included.
2. After the product has been unplugged from the power supply and then plugged into the same USB port, you need to click the installed software again to establish the connection before it can be used. If you connect another USB port of the same computer, the computer will automatically re-download the driver and software installation, and the customer needs to enter the software to connect.
【Portable USB Router】This is a new LTE 4G USB memory stick that integrates with WiFi hotspots to support up to 10 WiFi users connecting via WiFi at the same time. Simply plug directly into the laptop’s USB port to transfer data. It’s not only a USB modem, but also a WiFi hotspot, so you can enjoy WiFi with family and friends
【Large Memory】4G router support to expand small memory card up to 32GB(not included), more capacity can do more. USB 2.1, standard 6-pin SIM card interface, memory card connector (excluding SIM card and memory card)
【Plug and Play】as long as there is electricity, you can easily go online. Simply plug directly into the laptop’s USB port to transfer data. Support Firewall, Support OS: 32/64 bit: For Win 2000/2003/XP/Vista/7/10, for OS 10.4 or above, for Linux
【Note】This USB WiFi Router requires the use of a SIM card. After the product has been unplugged and then plugged into the same USB port, you must click the installed software again to connect before it can be used. If you connect another USB port on the same computer, the computer will automatically re-download the driver and software installation and the customer needs to enter the software to connect
