USB Plasma Lighter Flameless Electric Double ARC Dual Pulse Torch Rechargeable Lithium Power Battery (Blaze – Smooth Black)
Price: $10.99
(as of Apr 20, 2025 04:15:18 UTC – Details)
Lithium Lion lighters are designed to light just about anything with powerful beams of 900 degrees heat electricity. This lighter produces a clean and even heat that is eco friendly!
How Does It Work?
When you push the ignition, an electric current flows between the 4 nodes. The air in between the nodes is ionized, producing a super hot cool looking purple blaze that emits 900 degrees of heat! Lithium Lion lighters can light just about anything! Muahahaha… Sorry, we got a little too excited there..
Versatile
Lithium Lion lighters are perfect for use anywhere: indoors, outdoors, in a car, in a cave, in the sewer, under a bridge, Ryan’s house, on a mountain top… you get the idea. The precise controlled electric beams will light your favourite candles, incense and a lot of other stuff!
Windproof & Flameless
The electric beams won’t blow out so these lighters will work in the windiest of conditions!
USB Rechargeable
Recharge your Lithium Lighter via any standard USB port with the cord that is included. The lighter requires approximately 90 minutes of charge time for a full charge. Get more than 100 lights on a full charge!
Contains No Butane or Lighter Fluid
Don’t waste your money on disposable lighters that are bad for the environment! Don’t want to go through the hassle of refilling messy and smelly lighters? Lithium Lion Lighters are the eco-friendly answer!
Versatile: Lithium Lion lighters are perfect indoor or outdoor. The precise controlled electric beams will light your favorite candles, incense and a lot of other stuff!
Windproof & Flameless: The electric beams won’t blow out so these lighters will work in the windiest of conditions!
USB Rechargeable: Via any standard USB port with the cord that is included. The lighter requires approximately 90 minutes of charge time for a full charge. Get more than 100 lights on a full charge!
Contains No Butane or Lighter Fluid: Don’t waste your money on disposable lighters that are bad for the environment! Don’t want to go through the hassle of refilling messy and smelly lighters? Lithium Lion Lighters are the eco-friendly answer!
