Trucker Access › Forums › Diesel News › UpTake Tire Insights Reduces Failures by 83% – Maintenance
- This topic has 0 replies, 1 voice, and was last updated 9 months, 3 weeks ago by
EazyRiDer66.
AuthorPosts
June 12, 2024 at 11:45 pm #25311
EazyRiDer66
Keymaster
Tire Insights is a new suite of solutions designed to revolutionize fleet maintenance and vehicle safety.
Uptake, a data analytics provider for fleets and industrial machines has announced its new Tire Insights tire management program.
Tire Insights is a new suite of solutions designed to revolutionize fleet maintenance and vehicle safety, the company said.
Uptake noted that tires are a primary cause of roadside breakdowns, accounting for over 50% of such incidents.
Reduces Unsafe Driving
Uptake’s Tire Insights allows fleets to monitor and manage tire health. The company said Tire Insights can curtail significant failures by over 80%.
The product suite, which currently includes Tire Leak Insights and the Tire Pressure Monitoring System (TPMS) Insight, helps fleets improve fuel efficiency by 5%, avoid costly downtime, increase operational efficiency, and reduce unsafe driving days by over 90%.
These factors lower overall tire maintenance spend, Uptake said, which is often the highest expense in fleet management.
Tire Leak Insights enable early detection of air pressure loss, enabling fleets to address potential issues before they escalate. The tool monitors subtle pressure changes and alerts drivers and maintenance teams proactively, helping to avoid severe tire-related incidents, prolong tire life and enhance road safety.
Tire Pressure Monitoring System (TPMS) Insight detects sensor anomalies that could lead to inaccurate pressure readings. This critical feature ensures data reliability of pressure monitoring and allows for timely interventions, maintaining tire integrity. The system’s accuracy and speed make it an indispensable tool for modern fleet operations.
“We have proven Tire Insights are actionable and substantially reduce the risk of tire failures and their associated costs,” said Brian Silva, director of data sScience at Uptake. “We regularly catch tire leaks the same day they start instead of two to three weeks later, when they are typically discovered.”
A Modern Tire Management Solution
According to Silva, over 80% of fleets depend on outdated methods for tire maintenance. Depending on simpler, threshold-based alerts that can lead to false positives, according to an Anyline survey.
Uptake said its solution uses advanced analytics to detect tire-related issues, such as leaks, sensor malfunctions and pressure drops, one month earlier than conventional systems.
The system leverages asset and axle tire pressure baselines, working together to identify and address pain points before they escalate into severe safety concerns. With these technologies, Uptake customers can keep drivers safe and lower operational costs, substantially impacting their bottom lines.
“At Uptake, we are relentlessly focused on product innovation and excellence,” says Adam McElhinney, CEO of Uptake. “Our new Tire Insights integrate seamlessly with existing tire pressure monitoring systems and leverage historical data to enhance insights and improve fleet maintenance strategies significantly.”
In addition to new tire monitoring solutions, Uptake launched a Fleet Insight Assessment Dashboard for a more granular analysis of fleet subsystem health. The new tool offers a high-level overview of Insights produced by a fleet over the past 90 days. Using the Dashboard, fleet managers can quickly cut through the noise and empower their maintenance teams to identify potential pain points, ultimately making smarter decisions faster.
Uptake’s Tire Insights are now in a piloting phase with select customers.
AuthorPosts
