- This topic has 0 replies, 1 voice, and was last updated 1 year ago by .
Viewing 1 post (of 1 total)
Truckers Forum And Lounge ๐๐๐ป
Trucker Access › Forums › [Locker] Cobra RX680 38-Mile Two-Way Radio Set
get items delivered for easy pickup
Post
by EazyRiDer71 ยป
The Cobra RX680 contains a pair of a rugged, waterproof walkie talkies that are perfect for most outdoor conditions. With up to 38-mile range, Waterproof (IP54) Rating, NOAA Weather Alerts, built-in LED flashlight, and more, the family-friendly RX680 walkie talkies are ideal for outdoor adventures.
60 PRESET CHANNELS โ Easy access to 22 standard FRS channels plus 38 pre-programmed channel/privacy code combinations to secure your conversations from surrounding hikers, hunters or wherever your adventure takes you.
NOAA WEATHER CHANNELS โ Get 24/7 access to NOAA weather channels so you can always be prepared and connected with those you are traveling with in the instance you run into bad weather conditions.
VOICE-ACTIVATED TRANSMISSION (VOX) โ Hands-free usage to automatically transmit when you speak so you can keep your arms and hands free. Great when hunting or for construction sites or other working conditions.
PATENTED VIBRALERT โ Enhanced vibrating feedback notifies you of incoming transmissions, so you never miss an alert. The built in LED Flashlight is a great addition to your camping accessories or enable the SOS function with the push of a button.
