Price: $39.99
(as of – Details)
How to Use:
Open the back cover, install the standard SIM card, install the battery, and start the machine. Please refer to the instruction manual for details.
Specification:
Item Type: 4G WiFi Router
Material: ABS
Model: H80
Color: White
Type: Plug in Card
Card Slot: Standard SIM Card
Battery Type: Built in 2400mAh Lithium Battery (included)
4G LTE Band: B1 B3 B5 B40
3G UMTS WCDMA: B1
WIFI: Support 802.11 b g n
Sharing: 10 Users Maximum
Package List:
1 x 4G WiFi Router
1 x Battery
1 x Charging Line
1 x Manual
Note:
Please check whether there is a partition sticker at the built in battery interface before powering on, if there is, please tear it off and power on, otherwise it cannot be powered on.
Wide Application: 4G WiFi router is mainly for car users, business travelers and outdoor travelers, supporting 10 users at the same time. Support for Windows 7, for Windows 8, for Windows 10 and for Linux.
2400mAh Battery: Portable WiFi router has 2400mAh high capacity battery with up to 72 hours of standby; WiFi LED smart display, easy to operate.
Slim and Lightweight: Mobile WiFi hotspot is slim, compact and portable, so whether you work from home or travel, your WiFi follows you around the world.
Easy Connection: WiFi router can easily connect to WiFi by simply inserting a standard SIM card, whether it’s a cell phone, laptop, desktop or tablet (SIM card not included)
