Price: $105.99
(as of Apr 08, 2025 18:30:38 UTC – Details)
DALLUX Truck Bus Digital Wireless Backup Camera Kit with 7 inch Built-in DVR Digital IPS Monitor and HD 1080P Rear View Camera
DALLUX–a proffesional manufacture of vehicle backup camera and monitor since 2002 year
20 years experience in the field of automotive electronics, the spirit of pursuing excellence never stop. We not only supply high quality vehicle cameras and monitor products, but also supply various driving safety solution for automobile manufacturers and fleet management company,etc.
This High definition digital wireless backup camera system is complete with a crystal clear 7″ DIGITAL IPS panel monitor, it is a storage capacity 128GB DVR built-in monitor for 4 channel camera video recording, a 130°wide viewing angle HD 1080P reverse camera with 50 foot infra-red night vision. The rear view camera is completely weatherproof with an IP69K rating, strong and reliable, shock resistant, with a 20G vibration and 100G impact rating (highest in the industry).
This WCS7000 wireless reverse camera system can be use on Bus, Truck, Van,Trailer, RV, Campers, Motor Home, School bus, Pickup Truck, Travel Trailer, Oversized Truck, Dump Truck, Camping Trailer, 5th(fifth)wheel RV, Excavator, Horse Trailer and Agricultural Machine in farm for rear view vision cab cam monitor, stable digital wireless signal, 984ft super long wireless transmitting distance, vivid image and excellent night vision function provide drivers a safety driving in date time and night time.
DALLUX Digital Wireless Built-in DVR Monitor Specification
7 inch digital color IPS monitor: Sharp image at any view angle.
Resolution: 1024*RGB*600
Video System: PAL/NTSC automatically
Power: DC9V-32V
Built-in DVR: Maximum storage 128GB
Recording format: AVI
Power consumption: about 6W
Video: 1/2/4 video inputs
Menu control camera rear view or front view image,button switch the full screen and split screen.
DALLUX High Definition Wireless Rearview Camera Specification
Image Sensor: 1/3 “Color CCD
Resolution: 1080P
Horizontal viewing angle: 130 degree
Lens: 6 layer glasses HD lens
Operating voltage: 9V-32V
Wireless Line of Sight Range: 984ft
Night vision: 18pcs superb IR light,night vision distance 50ft.
Operating temperature: -20~80 degree centigrade
Operation Frequency: 2400 ~ 2483.5MHz
2.4G Hz Digital Wireless Backup Camera Monitor System
Super Sharp Natural Color Image
Backup camera built-in 1/3 inch color CCD image sensor. HD 1080P resolution, 1/3 inch image sensor unit pixel area is bigger than 1/4 inch, so the image quality is better, CCD better than CMOS image sensor on sensitivity, resolution and noise control, complete with 1024*RGB*600 digital IPS monitor, it can give you a pretty sharp natural color image.
Waterproof IP69K Rating
Backup camera comes with patent design casing, special waterproof glued process. Completely waterproof with an IP69K rating. This is actually the highest IP rating there is and means the camera will work fine in all weather conditions such as pouring rain & violent storms.
Excellent Infra-red Night vision
With 18 infra-red lights, the backup camera will be able to see up to 50ft even in complete darkness! This image sensor can have a very good night vision performance under low illumination, it will be even without any ambient light at all. Unlike other CMOS image sensor camera, it will not change the color to be pink color.
130 degree Viewing Angle No Blind Spot
Backup camera comes with 6 layer glasses high definition lens, with an ultra wide 130°viewing angle, the backup camera will provide a complete view from behind your vehicle. This ensures complete safety with no blind spots.
Adjustable Parking Line and Rearview or Normal Image
The menu on LCD monitor can adjust the camera with or without the parking assistant line, as well as flip screen image between a mirror view image or a front view image. This allows the connected cameras to be used either as backup or forward facing cameras.
Package Content
Package Included:
1 x 7 inch Monitor, 1 x Reverse Camera,
2 x Power Cord, 2 x Mount bracket,
1 x Screw Kit,1 x Car Charger,
2 x Antenna,1 x User manual.
Model Number
WCS7000
WCS7001
WCS5000
RCS7000B
RCS7001
Wired/Wireless
Wireless
Wireless
Wireless
Wired
Wired
Display Size
7″ IPS LCD
7″ IPS LCD
5″ IPS LCD
7″ TFT LCD
7″ TFT LCD
Waterproof Rating
IP69K
IP69K
IP69K
IP69K
IP69K
Night Vision
IR night vision
IR night vision
Starlight night vision
IR night vision
IR night vision
Guidelines
Driving Record Function
Mirror/Normal Optional
Snow Resistant
Apply To
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach
【Wide View Angle】The wireless backup camera 150°wide viewing angle,The image is super clear and any distortion is reduced to a minimum. Thus, you will get to enjoy a flawless parking and driving experience. The image could be fliped between mirror(rear view) and facing(front view),Backup lines optional to turns on/off. Built in record function and loop recording, continuous record when memory card is full and auto erase old files.
【4CH 1080P Monitor】The large buttons on the display are easy to operate, durable as well as extend the service life. It can take up to four cameras.B07TWWT2F6 camera is compatiable with it. Also you can use the side view bracket B08JG1XD45 as side view camera
【Built-in DVR & Wide Voltage】This 7″ IPS panel wireless monitor built-in recorder,support real time recording and video playback,maximum storage 128GB.It support 10V-32V wide voltage input for a Wide Variety of Large Vehicle Semi-Trailer/Box Trucks/Campers/5th Wheel/Tow Trailers/Bus/RVs.
【Hightest IP69 Waterproof Camera】You can install it anywhere near the reversing light. It also has fog resistant with a Super night vision ability. IP69K Waterproof Camera with 150° viewing angle,very easy to hook up to combat bad weather. The wireless backup camera is night vision with 18 infrared lights.
