Price: $8.99
(as of Apr 09, 2025 18:45:22 UTC – Details)
** REMEMBER: In Compliance with DOT Regulations-Butane Fuel is Not Included, Please Refill It Before Using. **
Our Mini Torch Lighter Features 45 Degree Rotatable Head Provides You with Enhanced Flexibility and Precision. Suitable for Indoor and Outdoor Activities, Such as Lighting Candles, Fireworks, Grills, Fireplaces. Also Useful for Lighting your Fireplace, Gas Stove, Oven, Hob, Tealight
Say Goodbye to Disposable Lighters! Our Torch Lighters are Butane Refillable, Offering You a Cost-Effective and Eco-Friendly Solution. Keep the Fire Alive by Easily Refilling the Butane Fuel and Enjoying Consistent Performance without Waste.
HOW TO REFILL YOUR TORCH LIGHTER
1. Hold the Lighter and the Butane Can in an Vertical upside-down Position.
2. Align the Nozzle on the Butane Can with the Refill Inlet Valve on the Torch.
3. Press the Stem of the Butane Can into the Refill Valve in 5-second Bursts to Inject the Butane.
4. Repeat as Needed in 5 Sec Intervals to Fill the Tank.
NOTE:
A) It is Important to Keep the Torch inverted to Avoid Injecting Air into the Tank.
B) It is Important to Ensure that the Refill inlet valve on the Torch and the Nozzle on the Butane Can are Aligned.
C) IF You Experience Gas Leakage with Hissing Sound While Refilling the Torch Lighter, You May not be Holding the Lighter and Butane Can in a Straight Position, Try Adjusting. If it Persists, You May Need an Adapter.
Reliable&Safe, Safety Lock to Prevent Accidental Ignition, Child-Resistant Safety Mechanism Keeps Your Children Away from Using Them.
Butane Refillable, Unlike Disposable Lighters, Our Torch Lighters are Butane Refillable, Offering you a Co-Effective Solution.
Wind Resistant, This Mini Butane Torch Lighter Works Well Even in Wind Conditions with an Effective and Hot Flame.
Transparent Fuel Tank: Visible Butane Tank, Remind you When you Lighter Needs to Refill and the Check the Filling State. It Has 2.8g Capacity Butane Fuel to Ensure Long Last Using. (Butane Fuel is Not Included).
Multi-Purpose Lighter, Suitable for Indoor and Outdoor Activities, Such as Lighting Candles, Fireworks, Grills, Fireplaces. Also Useful for Lighting your Fireplace, Gas Stove, Oven, Hob, Tealight
Continuous Flame Mode: Press the Ignition Button to Light Fire, Turn the Safety Lock to “Lock” Position at the Same time, Then it will Keep Firing without Your Pressing.
