Price: $14.99 - $9.99
(as of Apr 09, 2025 21:15:22 UTC – Details)
Torch Lighters, 4 Pack, 6-inch Butane Lighters, Adjustable Flame Windproof Butane Refillable Gas Torch Lighters, Long Lighters for Candle, Grill, BBQ, Fireworks, Camping( Butane Not Included)
HOW TO REFILL BUTANE LIGHTER
1.Choose the Right Fuel, Premium Butane is Highly Recommend, As Lower Quality Butane Has Been Know to Clog Lighters.
2.Bleed the Lighter, Hold the Lighter in Vertical upside-down Position, Take the Air out of the Gas Tank by Pressing the Refill Inlet Valve with a Small Screwdriver until No Hissing Sound Heard. Hold the Lighter away from Your Face when Drain the Air Out.
3.In order to Prevent an Unexpectedly High Flame after Refilling, Turn Flame Height Adjuster on the Bottom of the Lighter to the Lowest Setting by Turning Flame Adjustment Knob Clockwise (See Fig4,Flip out the Tab with your Finger Nail).
4.Injecting the Butane, Hold the Lighter and the Butane Can in an Vertical upside-down Position, Press the Stem of the Butane Can into the Refill Valve in 3-second Bursts to Inject the Butane. It is Normal for a Small Amount to Spray around the Edges of the Valve.
5.Before Igniting the Lighter, Please wait 3-4 Minutes, this Allow theExcess Butane to Evaporate and Gas Inside Lighter to Reach Room Temperature.
6.Turn the Flame Adjustment Knob back 1/2 turn Counter Clockwise. Attempt to Light the Lighter. If the Lighter wonβt Light, Turn the Adjustment Knob Another 1/4 turn and try again. Keep Adjusting the Knob in 1/4 turns until the the Flame Height Reaches the Desired Level.
WARNING
KEEP AWAY FROM CHILDREN
Refill/Empty only in a well ventilated area.
Never attempt to refill or empty near any heat source, sparks or flame.
No smoking during refilling or emptying.
Do not keep it igniting for more than 10 seconds
ADJUSTABLE&REFILLABLE TORCH LIGHTERS: An Adjustable Flame Knob on the End of the Mini Torch Utility Lighter Lets you Easily Control the Flame Height, Providing Extra Flame Height when Needed. Refillable Lighter, Reusable Lighter.
VISIBLE FUEL LEVEL WINDOW: This Mini Pen Torch Lighters has 2.8g Capacity Gas to Ensure Long Last Using. With Visible Fuel Level Window, Which Will Remind you When your Lighter Needs to Refill and Check the Status of Butane Refilling.
SAFE AND RELIABLE LIGHTER: This Butane Torch Lighter Nozzle with Copper Material was Designed for Supporting Continuously Flame and Longer Using Times, Cooling Hole and Ceramic Port Was Designed For Maximum Heat Dissipation to Prevent Damage Caused by High Temperature.
MULTIPURPOSE LIGHTER: 6 inch Butane Lighter, SIZE:6.03 x 0.79 x 0.79 inches, Weight: 2.04 OZ, Compact and Portable, Perfect for your Indoor Activities. Suitable for Lighting Candles, Gas Stove, Oven, Hob, Tealight.
ATTENTION: IN Compliance with DOT Regulations-Butane Fuel is Not Included
