Price: $9.99
(as of Jan 23, 2025 22:00:38 UTC – Details)
The Torch Flame Lighter is made of high quality, light and durable aluminum alloy material with a super strong flame that instantly ignites items. It has a butane gas window and flame size adjustable. Our lighters are perfect gift for any occasion and holiday like Birthday, Father’s Day, New yearβs day, etc.
Specification
Starter: Piezo ignition
Material: aluminum alloy
Product size: 6.1β x 0.78β x 0.78β(154mm x 20mm x 20mm)
Weight: about 2.3 oz (58g)
NOTE
Please fill up the lighter with the butane gas canister before use.
Keep it out of the reach of children at any time.
The lighter can produce strong flame, Please donβt face the jet ligher to your body or any flammable objects.
The lighter won’t ignite at the lowest regulator setting because there is no gas pressure at this setting, please adjust the regulator at the bottom.
Burning time: once less than 1 minute to prevent overheating
Please make sure the regulator is turned to the minus side when filling.
After refilling, please wait for 1-2 minutes, this can make the temperture of lighter body to reach the room temperature before. Then the lighter can be used.
Package list:
1 x Torch Flame Lighter
1 x box
Gas Window:There is a small visible window on the side of the lighter,it allows you to see the level of butane gas remaining in the lighter’s tank. It helps you know when you need to refill the lighter before it runs out.
Refillable:This lighter is refillable, making it a more cost-effective and environmentally friendly option than disposable lighters. You can refill them with a long nozzle butane canister.
Adjustable Flame:There is a rotatable flame regulator at the bottom of the lighter, you can adjust the flame size at any time without tools.It can be folded when not in use.
The lighter contains no butane gas. Please re-fill it before use.
