Price: $8.99
(as of Mar 16, 2025 06:15:17 UTC – Details)
Product name: Double Flame Lighter
Weight: about 65g
Note: Weight and size are measured purely by hand, there may be errors, please understand.
Refilling Tips?
Step 1: Choose Butane
Choose the right butane is very important for lighters. In general, high purity and high-quality butane can prolong the life of lighters.
In addition, the butane with low purity and poor quality contains too much air, which will cause the lighter to fail or fail to ignite during use.
Step 2: Release Gas
Before refilling a butane torch lighter, it is necessary to drain any remaining fuel from the lighter. Open the flame adjuster to set the flame height adjuster to a minimum and use a small screwdriver or other tool to push the refill valve down to release the gas in the tank. Keep away from your face and clothes while operating.
The positive and negative signs will indicate a larger or smaller flame.
Step 3: Filling & Adjust Flame
Make the lighter is upside down and place the butane fuel nozzle into the filling valve,refill the lighter about 5-10 seconds. The filling time can be increased or decreased according to the actual capacity of the tank.
After filling please wait for two minutes to get reach room temperature before use the lighter.
Please remember to adjust increase the flame before using the lighter.
If you need any help
Please [Contact Seller]directly from Amazon Buyer Center against your order #. Our friendly customer service normally replies to you within 24 hours.
🔥Universal refill valve,after you fill the lighter,please adjust the flame dial at the bottom before igniting. Butane is not included due to airmail reason.
🔥Creative valve switch, push up the side slide button to close the valve and push down to open the valve for ignition. It will not misfire in te pocket and please keep away from children.
🔥Circulating gas filling:Flame adjustment valve for open flame on the left,the right side of the blue flame flame adjustment valve.Rotating adjustment device, “+” “-” direction rotation to adjust the flame size.
🔥Is a perfect gift for dad, brother, husband, friends and families in any occasions like Birthday, Father’s Day, Anniversary, Thanksgiving, Christmas etc.
