Price: $16.99 - $9.99
(as of Mar 21, 2025 13:00:36 UTC – Details)
Let SUPRUS bright your life!
Arc lighter also can be used as Flameless Candle Lighter, Plasma Bean Lighter, Camping Lighter, BBQ Lighter, Kitchen Lighter, Torch Lighter. Outdoor Utility Lighter Suit for birthday candle, BBQ grills, camping, and many other uses.
Package Include: 1 * USB Rechargeable Windproof Arc Lighter, 1 * Micro USB cable, 1 * User manual
SUPRUS Candle Lighter
NO FUEL. NO GAS. NO FLAME. NO HARM.
EASIER, FASTER & CLEANER PORTABLE DEVICE RECHARGEABLE BATTERY HIGH SECURITY WINDPROOF DESIGN EASY MAINTENANCESPECIALLY DESIGNED HANDLE
Warning: Please clean the product head after using which can effectively prevent the head from burning and melting.
Frequently question respond
Is this easy to light? My mom doesn’t have the strength to use a traditional candle lighter.
Yes, it is easy to light. All you have to do is press the little power button that is on it and then hold it to the wick. The candle will be light in seconds.
Is the rechargeable lighter safe to use to light gas stove?
Yes, it can be used for light gas stove. And for the safety of consumer, the igniting spark will auto stop beyond 10 seconds per igniting.
Does this electric arc lighter come with USB charging cable and what type of charging cable?
Yes, it comes with a charging cable. You can use the USB port to charge it through computer. If it is missing, you can use a mobile phone charging cable. They are the same kind of charging cable.
How to clean the tip parts of the lighter?
The tips are made of heat resistance ceramics ( the ceramics do not burn). But carbon from candle soot and charring wax produced by candle burn when lighter literally jamming it into the wick . You can clean the tip parts of lighter with soft cloth .
Children Safety Button & Battery Notification
Need to slide out the tip and press the activation button. Slide-Out Tip is design for preventing mistakenly touching.
This is the upgraded SUPRUS arc lighter which can display real time battery volume. When 4 LED lights on the barrel turn on, it is full charged.
Longer Flexible Neck
The front section can be rotated 360 degrees. This design make it much easier to use in any direction. The arc lighter is not only windproof, but also let you get away from fire burn.
Hanging Hook
Easy hang, it can be hung on kitchen walls, windows, doors and etc, convenience.
This candle lighter is very easy to use, lights up quickly and very affordable. It is much more effective than regular candle lighters due to its bendable top.
It’s so easy to use! Charges using a micro USB cable and after using it at least 50 times it still holds its charge! It is also so versatile because the neck can be bent to any direction.
It lights candles quicker than a regular lighter with no risk of burning yourself. It also gets wicks that are farther down in a candle with ease. Charges quickly and the battery lasts a long time.
Item Dimensions
7.48 x 0.59 x 0.35 in 10.27 x 0.59 x 0.59 in 10.62 x 0.78 x 0.47 in 7.28 x 0.59 x 0.43 in 7.87 x 0.98 x 0.59 in
Item Weight
1.23oz 2.4oz 2.32oz 1.72oz 2.12oz
Battery Capacity
220mAh 220mAh 360mAh 170mAh 280mAh
USB Rechargeable and Convenient Design – The eco-friendly candle lighter with powerful USB rechargeable Li-ion battery can be recirculated 500 times, The portable USB cable can connect with computers,power banks, etc,so you can charge it everywhere you want and whatever time.
Windproof and Plasma Technology – The Arc lighter adopt flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather, ensures easily use it under any weather conditions, Perfect for Grill and Outdoor Lighter, Camping Trip.
Safety and User-friendly Design – The candle lighter with Child-proof switch at the on/off button protects children from igniting accidentally,beyond 7 seconds the spark will auto stop ,7 seconds automatically shut down avoids too high-temperature damage. LED Battery Display tip you real-time battery volume by 4 LED lights.
What Will You Get – 2x SUPRUS arc lighter, 1x USB charging cable, 1x User Manual. When you have any issue with your lighter or service system close return window, please do not hesitate to contact service line.
100% Satisfaction Guaranteed.- 90-Day Money Back Guarantee and 1-Year warranty Against Manufacturing Defects so try them risk-free today. We are confident that our product will meet or exceed your expectations. Customer satisfaction is our priority.
