Price: $12.95
(as of Mar 25, 2025 14:15:24 UTC – Details)
Boundaries
Create & configure customized perimeters in any location. You’ll be alerted the precise moment your vehicle has entered or exited a boundary.
Detailed Information
Whether you need a paper trail of services rendered or a log of distance driven, our reports track it all.
Customized Alerts
Only receive alerts about the events and information that is important to you.
Performance Mode – From a smooth real-time feel when following a tracker on the map to ultra-fast alerts. Performance Mode offers the ultimate tracking experience.
Power Saving – Power Saving allows you to maximize the battery life of your tracker for those times when you need to go longer without charging.
Updates on-the-fly – Change the Reporting Mode of your trackers over-the-air, in seconds, as many times as you like, and from your phone or computer – it’s that easy.
Included in all Plans – We believe Reporting Modes is vital to having an amazing tracking experience – that’s why we’ve included it in all of our plans, at no extra cost.
All Weather Tracking
Water resistant, weather proof, and dirt proof – means that you can track your equipment in any weather, anywhere and keep your Spytec GPS tracker safe and dry.
Custom Alerts and Boundaries
Set up alerts tailored to your needs. Create boundaries and get alerts when something has entered or exited an area.
Easy-to-Use Software
Our mobile and desktop apps give you clear visibility of your trackers and data insights. Watch your tracker move on a map, get reports, customize preferences, and more.
Data and Reporting
Get the data you want for both present and past tracker activity. See routes, speed, timestamped arrivals and departures, stops, and more.
Unlimited Tracking Range
Thanks to the network of satellites and 4G data networks, our trackers have unlimited range and are always logging and transmitting data.
Flexible Battery Life
Select the update rate of your GPS tracker on the fly, allowing you to opt for longer battery life or more frequent updates.
With Spytec GPS Powered by Hapn You Also Get:
Changeable Maps – view your tracker’s activity in dark mode, light mode, or a satellite view.
Flexible Measurements – track and report in either metric or imperial units.
Follow Mode – watch your tracker move across the map in real time.
User Roles – track with your team, multiple users and tiered permissions allow for group monitoring in the same account.
Webinars & Help Center – Our self-help channels were built to ensure that you are up and tracking with no questions remaining.
Reporting Modes: This feature allows you to customize the update frequency of your trackers, giving you greater control over the battery life and the speed of updates. In an emergency, such as a stolen vehicle, a fast update frequency is needed. When you cannot charge a tracker once a week, you need to maximize the battery life. Reporting modes let you do whichever you want.
Go Back in Time – Time Machine is our feature that allows you to visualize the history of any tracked asset. Follow along and see all the trips, stops and alerts that happened along the way.
You Control the Battery Life: Tracker update speed can be customized on the fly to update as often as every 5-seconds for immediate visibility, or as infrequently as once a day to maximize battery life and last up to 14 days. Use your device how you need to use it.
Lifetime Warranty & Affordable Subscription: This device requires a subscription to our easy-to-use mobile and desktop apps. Activate the device, choose your plan, and start tracking. Subscriptions start at $25/month(USD) annually or $30/month(USD), month-to-month. Get free 24/7 support and a lifetime warranty on GPS trackers with an active annual subscription. International coverage available – additional configuration required, contact customer service.
