Price: $39.99
(as of – Details)
【10000mAh LARGE CAPACITY RECHARGEABLE BATTERY】SprGri’s solar radio uses a rechargeable 10,000mAh lithium-ion battery, which is twice or even four times the capacity of other solar radios on the market, greatly increasing the radio’s battery life. Radio operation lasts up to 90 hours when fully charged. It can also be used as a power bank for your mobile phone in an emergency.
【3 WAYS TO POWER UP】Bad weather always causes power outages. With the hand crank and solar panel, the radio can be powered up in an emergency. USB Type-C fast charging is the main power source for daily use.
【SUPER BRIGHT FLASHLIGHT& READING LAMP】If you are an outdoor enthusiast or need to go to places without light, this radio with a 3-mode torch is a great choice with a maximum illumination range of over 20m to light up your way. The reading light can be used for reading time while camping.
【SOS ALARM WITH FLASHING LIGHT】 The solar radio is equipped with an SOS function. If you encounter a dilemma or danger, or are in a dark place, long press the SOS button to activate a loud siren and flashing high beam light to alert others.
