Price: $899.99 - $799.99
(as of – Details)
Solar Generator 1021Wh,Portable Power Station 1000W and 1x120W Solar Panel with 2x110V/1000W AC Outlets,Solar Power Generator with Lithium Battery Pack for Outdoor RV/Van Camping,Overlanding
√Eco-Friendly – With MPPT Technology:COOFLY S1000S solar generator can gear up with a COOFLY 120W solar panel, upgrading into a Solar Generator 1000 System. Built-in MPPT (Maximum Power Point Tracking Control) so it can extract the maximum power from the solar panel, optimizing the utilization of variable power sources like a solar generator.
√Powerful& Versatile Ports: The S1000S features 2 standard pure sine wave AC outlets, which will provide extra capacity to power more AC devices and appliances,1*USB-C PD 100W output, 2*USB-A 18W outputs, 1*Car port, 1*DC output, COOFLY power station can power 7 devices at the same time (as long as they draw less than 1000W combined). Each switch can control each output module.
√Outstanding Safety: Equip with COOFLY’s quality built Battery Management System to ensure the battery’s safety level, while optimizing its performance. The One Button design allows an easy use for you to operate, anytime and anywhere – whether for camping, RV, tent
√Foldable Design & Kickstand Setup of Solar Panel – The foldable solar panel with a protective case can avoid it being damaged by collisions. The kickstand setup helps the solar panel collect sunlight at the best angle for conversion to power. Let’s start enjoying the off-grid adventure.
√What You Get: 1*COOFLY S1000S Portable Power Station ,1*120W Solar Panel, 1*Panel Protective Case, 1*AC Power Adapter, 1*Car Charger, 1*MC4 to DC7909 Cable, 2*User Manual.
