Price: $15.99 - $17.99
(as of Mar 23, 2025 11:30:26 UTC – Details)
Why we need slow cooker silicone liner?
If you have a picky eater in your family,It suits you very well,can now run 2-4 different meals at the same time,or 2-4 flavors of the same thing,family dinners and friends gatherings,crock pot silicone liner can cook more meals in less time and make meal prep easier,they also keep the moisture and nutrition of food so you can enjoy a healthier mealSay goodbye to the nightmare of cleaning heavy slow cookers pots,it can avoid direct contact between food and the bottom of the slow cooker,with no more food residue,grease,or dirt on the base,thus extending the life of the slow cooker,clean up silicone crock pot divider is a breeze with hot water,qr throw it in the dishwasher,more time to accompany familyIt can choose replace the disposable plastic crock pockets,made of food-grade silica gel crock pot bags liners,will not leach potential chemicals into the food you cook,environmental protection,leakage prevention,non-melting,not easy to damage,You can save money in the long run
Detailed dimensions of three versions:
2-in-1 size : 8.5 X 5.3 X 4.3 inches = 2PACK
3-in-1 size : 8.5 X 5.3 X 4.3 inches = 1PACK + 5.3 X 4.25 X 4.3 inches = 2PACK
4-in-1 size : 5.3 X 4.25 X 4.3 inches = 4PACK
Unified size after combination :10.6 X 8.2 X 4.3 inches,Perfect for a 6 quart oval slow cooker,But most 7 8-quart oval slow cookers can also be used,Please check the size before you purchase
Slow cooker divider liner 2-in-1 design,Able to cook two different items in same cooker,or two versions of the same thing (spicy/not spicy,salty/not salty)
Clean up is a breeze,not having to soak the crock pot or scrub!silicone slow cooker liner can effective keeps crock pot free from sticky food residue and scratches,Dishwasher Safe
This is a crock pocket made of food-grade silicone,BPA-free,reusable,leakproof,heat resistant up to 464℉,compare to plastic liners,helps minimize potential chemicals leaching into the food you cook
It can also be used in air fryers,ovens and microwave ovens,refrigerator storage (Note: The temperature needs to be controlled between -20 to 464℉)
Each crock pots liner is designed with 2 small handles,which makes it easy to lift and take out the liner from the slow cooker
Foldable and easy to store,And after folding into a small bowl,you can also put your favorite snacks,fruits and other foods
2 packs of fully expanded size : 10.6 X 8.2 X 4.3 inch,fits 6 quart and also fits most 7-8 quart oval slow cooker,Please check the size before you purchase
