sfDisplay.com,LLC. 138 Zippo Lighter Lighters Match Books Matches Display Case Cabinet Wall Rack Holder Lockable w/98% UV Door (Cherry Finish)
Price: $114.99
(as of Apr 06, 2025 11:30:30 UTC – Details)
Hand made from imported Australian beech wood. This furniture grade display case cabinet is of beautiful design and construction, very detailed and attractive, but also very affordable.
Perfect way to display your special zippo lighters or match books. Zippo case can hold up to 138 standard size zippo lighters as well as match books. Display case has lockable latches with keys to lock your display case. Felt black lining gives a great contrast with your items. Zippos will be displayed at a slight angel to give it a beautiful look. Each shelf has a over lip so your item does not tip over. Case comes fully assembled.
Display case comes standard with a 98% UV Acrylic Door, lockable latches with keys, and all hardware to mount the case to the wall. (item props shown are not included). 37.50″W X 19.55″H X 2.50″D space between shelves: 2 5/8″, 5 3/8
98% UV Ultra Clear Protected Acrylic Door
Each Shelf has on overlip so your zippos/matches do not fall off.
Fully Assembled With All Mounting Included.
Lockable Latches with Keys
