Price: $16.99
(as of Mar 06, 2025 21:15:18 UTC – Details)
FM/AM/WB RADIO
Large Digital Display with Backlight: A large FSTN display with clear numbers making it easy to read from any angle. 12H/24H time display mode with FSTN backlight. It is easy to use even for the elderly. Best gifts for your parents, Kids and lover!
Alarm Clock Radio with Sleep Timer:The radio sound on the unit will become an alarm sound. At the set time, the radio will automatically turn on and start playing, you won’t miss your favorite programs. Use the sleep function to set the radio off before sleep, so that you can fall asleep easily. The time can be set from 10 to 120 minutes.
Multiple Search Frequency Methods : Long press the Scan key for more than 2 seconds to automatically select frequencies. Turn and adjust the frequency manually. It can store up to 35 stations per band. It also can automatically delete preset unneeded stations. CH01.CH02.CH03 can save your favorite stations per band. Automatically deletes preset unneeded stations.
Battery or DC adapter powered: Powered by 2X AA batteries allow you to operate it even when the power in the house is out. Also you can use it with DC adapter. Highly recommend to keep one for emergency using special in hurricane or earthquake season
