Price: $89.99
(as of Apr 14, 2025 16:15:22 UTC – Details)
What are the features of this camera?
The camera has multiple features that can be used not just for reversing & hitching!
You can even use it for the security of your RV!
Motion Detection – With this function switched on, a push notification will be sent to your device once motion is detected.High-Quality Resolution – The high-quality resolution FHD provides crystal-clear images, so you can see exactly what’s behind you.24-Hour Loop Recording – By inserting a memory card (card not included), you will have recordings of footage to look back on, The video file will be automatically overwritten when it is full.Supports Multi-User – Multiple mobile devices can be connected to the camera via the mobile application. This is perfect if more than one of you is in the RV!
150ᄚ super wide-angle lens
Make sure you have a full view of the area behind your vehicle, making it easier to hitch in tight spaces.
Magnetic and sticky dual mounts
It can be installed on the front or side of the license plate according to your own needs, and can be adjusted at multiple angles.
Stable wireless connection method
With no messy wiring, you can enjoy a seamless and uninterrupted pulling experience.
Camera Set Includes
Camera*1
Magnetic base*1
Adhesive base*1
USB Cable*1
Instructions*1
Multifunctional Camera, Suitable for Many Occasions
【Multi-functional back up camera systems for truck】: This truck reversing camera can be connected to a mobile device via WiFi, and the mobile phone can download the APP to connect to the RV reversing camera for remote control. The truck wireless backup camera can also record videos and photos by inserting a TF card. DKCLCFQKX
【Smart Motion Detection and Voice Detection Double Arming Mode】: When the backup camera detects a moving object or sound, it will immediately send an alert notification to the phone. 3 photos are captured and transferred back to the app, while the recorded video will be stored on the memory card simultaneously (note: needs to be set in the app).
【Advanced Infrared Night Vision & 100% Waterproof】: With its 4 IR LED lights, the magnetic backup camera provides excellent night vision, so you can reverse and hitch even in low-light conditions. The camera is also built to withstand harsh weather conditions and is waterproof, so you can use it in any environment with confidence. DKCLCFQKX
【Multifunctional Stand, Suitable for Many Occasions】: The rear view camera is equipped with two bases, magnetic and sticky, which can be adjusted at multiple angles, and the built-in battery can be easily installed in various environments for managing stores, warehouses, home security, driving recorders, etc.
