Price: $46.03
(as of Sep 07, 2024 16:31:23 UTC – Details)
Why choose our reverse hitch guide camera?
HD Wide Angle: 160 ° high -definition wide -angle to ensure that reversing and driving are safer and simpler.2 Connection Modes: AP mode connection (Connect your phone to the camera’s built-in wifi, no internet required) and router mode connection (Camera needs to be connected to router WiFi, this mode is used for remote viewing)Excellent Night Vision: The camera has 6 non-invasive 940mm infrared LEDs, which can achieve excellent night vision effect.Support Multi-user: Multiple mobile devices can be connected to the camera through mobile applications.24h Cycle Recording: It supports SD card or cloud storage and save your recordings on SD card (up to 128G, not included) or cloud (secure). Easy to Install: Built -in recharged batteries and there are two installation methods available: magnetic or adhesive. No wiring and drilling troubles.Intelligent Detection: When the camera detects the mobile object, it will immediately send alarm notification to your phone.
Convenient Size
Only 1.2 in * 1.2 in * 1.2 in. Easy to install, does not take up space and is not easily damaged.
6 hours Battery
Large battery over 1500mAh for long battery life.
Good Heat Dissipation
The camera is equipped with heat dissipation holes to prevent overheating caused by prolonged use.
Package Includes:
Stand x 1
USB Cable x 1
Magnet x 1
Suction Piece x 1
Sticky Patch x 4
【Motion Detection and with Audio】This vehicle backup camera has has motion detection (this mode must be turned on in the APP settings). When the back up camera for rv trailer detects a moving object, it will immediately take a screenshot in the app to send an alarm notification to your phone. While the recorded video will be stored on the SD card(not included) or cloud (secure) at the same time. Also this wifi camera can receive audio and you can hear the sound through the APP.EIBAEBARLATP.
【Strong Magnetic and Sticky Base】The trailer backup camera comes with a removable camera base that rotates 360°, a base fixing magnet, four base fixing stickers, and 1 suction piece. You can choose magnetic mount or sticky mount according to your needs. This means you can instantly install it in a variety of environments without wiring or drilling. Increased mounting flexibility. You can adjust the position of the camera at any time without taking up too much space.EIBAEBARLATPRSEZEZL
【Convenient Size Wireless Camera】Our 4k video camera only 1.2 in * 1.2 in * 1.2 in. Easy to install, does not take up space and is not easily damaged. And our wireless backup camera for car is equipped with a 1500mAH high-capacity lithium battery, standby time of 6 hours. Do not worry about thieves power outages to commit crimes. Even if the power goes out, the battery power will work as usual. Perfect for rv reversing camera, management store, warehouse, home, car recorder, etc.XDRSFJW
【Your Ideal Vehicle Backup Camera】Rear view camera has 2 modes to connect (AP mode connection&router mode connection). The camera has its own built-in WiFi. if you want to use it as a backup camera for your car, you can just connect your phone to the camera’s wifi directly, no internet required. If you want to remotely control, then you need to connect the camera to a router. Just download the camera app then find the step-by-step description of the connection mode you want in the manual.
❗❗NOTE: If you encounter cannot connect or usage problems, please feel to contact us and we will do our best to help you solve it !
