RV Backup Camera Wireless Recording 2 Cameras – Plug and Play Pre-Wired for Furrion System Night Vision 4 Channels HD 1080P 7” Touch Key Monitor Rear View Camera for Trailer/Trucks/Camper Yakry Y28
Price: $197.98
(as of Apr 12, 2025 05:30:27 UTC – Details)
RV Backup Camera Wireless Recording 2 Cameras – Plug and Play Pre-Wired for Furrion System Night Vision 4 Channels HD 1080P 7'' Touch Key Monitor Rear View Camera for Trailer/Trucks/Camper Yakry Y28
►【Recording Function】The wireless trailer camera system has a recording function, like a ”DVR dash cam” that not only connects for reverse/driving use but also continuously monitors and records everything that happens, providing safety measures for you.
►【Compatible with Furrion Pre-wired RVs】With a bracket adapter and tail wire plug, the rv wireless backup camera for travel trailer can be installed easily in 10 minutes or less, designed to be compatible with Furrion pre-wired RVs.
►【HD 1080P Monitor with 4-channel & Split Screen Function】The monitor of rv camera system wireless has 4 channels, and you can add 4 cameras to the front, rear, and sides simultaneously to eliminate blind spots. At the same time, the monitor of back up camera for truck rv system supports full-screen/split-screen/quad screen.
►【Super Night Vision and High-definition 1080P Image】 The bluetooth trailer backup camera is equipped with 9 infrared lights and IP69 waterproof, providing clear images and vivid pictures for your safe driving both day and night.
►【Guideline on/off DIY and 170° Wide View Camera】The horse trailer backup camera wireless system allows you to turn on/off the guide line and adjust the width and height according to your needs. Y28 rv camera is equipped with a powerful sensor and 170-degree wide angle lens, give you a wide field of vision.
►【3 Years of Quality Warranty and Widely Used】Y28 rv back up camera for travel trailers system suitable for RVs, 5th wheels, trucks, trailers, campers, boats, motorhome, trucks, tractors, buses, and other vehicles. Yakry provides technical support and and a 3-year replacement warranty service for every rv rear view camera system.
