Price: $279.99 - $337.75
(as of Apr 12, 2025 22:00:35 UTC – Details)
DOUXURY Backup System for Bus, Truck, Trailer, Box, RV, Trailer, Tractor, the 5th Wheel
Why is the DOUXURY brand worth your choice?
▪ Quality Guarantee: We promise to replace the damaged part for free.
▪ Professional Service and tech Support: Have any question? Send an e-mail, get help from our technology support team. Customer Service Email: DouxuryUS@hotmail.com
Notice before order
—the front view camera and the 2 side view cameras are non-mirror-image camera.
—the rear view camera is mirror-image camera.
So if you want them all to be non-mirror-image camera or mirror-image camera, just contact me after order, I will change the camera according to your needs. Email: DouxuryUS@hotmail.com
How to Install?
All necessary accessories are included. Install the system according to the user manual book, and each line is labeled with a label explaining what it should be connected to. If you have any question, contact us anytime. Email: DouxuryUS@hotmail.com
Tips:
▪ Read the user manual before installing and using.
▪ Trigger wires do not have to be connected.
Specification:
Rear & Front View Cameras:
▪ Waterproof Level: IP69
▪ IR infrared led light: 18 pcs.
▪ Power Supply: 12-24V DC.
Side View Cameras:
▪ Waterproof Level: IP67
▪ IR infrared led light: 10 pcs.
▪ Lens Angle: 120°.
Quad View Monitor:
▪ Display Resolution: 800*480.
▪ DVR image: 640*480 pixels.
▪ Video Save: SD card support 32G .
▪ Power supply: DC-12V-24V.
What you can get:
▪ LCD Monitor x 1.
▪ 32G SD Card x 1.
▪ Front View Camera x 1.
▪ Rear View Camera x 1.
▪ Side View Cameras x 2.
▪ 16ft AV Cable x 1.
▪ 33ft AV Cable x 2.
▪ 66ft AV Cable x 1.
▪ All Necessary Accessories x 1.
Built-in DVR Recording Function: 7” large LCD monitor built in DVR recording function. Support to local playback and looping record, you can find the video easily in the monitor.
4 Split 1080p Monitor: Backup camera system supports quad view display, 4 video inputs from a front rear and 2 side view cameras can be shown on screen. Avoid Blind Spot. 1, 2, 5 minutes off display to protect the screen.
IP69 Waterproof Level: Excellent sealing technology, IP69 waterproof level. Safe to use in sunny or rainy days. Withstand extreme temperatures from -4℉~149℉.
Easy to Install: Wired rv camera system without any signal problem. One power cord supports the whole system. The camera only needs to connect the extension cable from the monitor.
Night Vision & Wide View Angle: Sharp clear night vision with infrared LED lights function, 170-degree wide viewing angle removes blind spots and safer driving.
Quality Guarantee: 24-Hour Online Customer Service, 30-Day Money-Back Guarantee, 365-Day Replacement Warranty and Lifetime Support. Have any question or need any help? Contact us, you will have our full attention.
