Price: $99.99
(as of Dec 25, 2024 13:30:44 UTC – Details)
2 Channel Video Inputs
The monitor with two way video inputs AV1/AV2–the default set AV2 for current system.
You can wire it for only rear view by powered with reverse lights for camera or full time constantly view by powered with running lights/car battery for camera.
Mirror & Normal Image
You can roate the image on the screen by “MENU”button to get your need:Mirror/Mir-flip/Normal/Flip.
Wired backup camera kit
It keeps great signal no matter where you are.This wired backup camera kit never has picture delay or signal issues, different from the unstable wireless products.
170° Wide View Angle
Upgraded rear view camera with a 170° wide viewing angle and 6 layered all glass lens makes you always have an eye on your surroundings and the full vehicle width.
18 IR Night vision & IP 68 Waterproof
The 18 IR lights brightness will atuomatically turn on/off according to enviorment.Make sure driving safety at night or bad days.
IP68 Standard Waterproof level allows it to work fine in most conditions.
Easy to install
The package includes all need parts, offering detail installation instruction.
7″TFT LCD Monitor Specification & Rear view Camera Specification
Screen Size 7 inch Display Component Color TFT LCD Resolution 800*480 TV System PAL/NTSC auto Operate mode key operation & remote control Power 12V-24V Image Sensor CCD Effective Pixels 752*582 pixels Lens Viewing Angle 170 Degrees(Pin Lens: f=2.1mm / F=2.0) Waterproof IP Rate IP68 Operating voltage 12V-24V Work Temp -20℃~+60℃
【7″ HD Digital Color Monitor】7″ monitor with super large HD(800*480) screen.This provides a super sharp image from the backup camera view.The monitor support 2 video inputs.Monitor automatically turns on and switch to AV2 rear view picture when reversing .
【Designed For Lots of Vehicles】There are 2 different mounts for the monitor for optional,you can put the monitor hanging overhead or standing on dashboard .Our backup camera system includes 20 meters 4 pins aviation extension cable ,which is more suitable for Truck/rv/Bus/Vans/5th wheel/Camper/Hitch hotel,etc.
【IP68 &18 Infrared Lights】 International Standard IP68 waterproof level, make sure the camera can work well in all weather conditions.18 Infrared lights provide excellent night vision performance,this night vision will be even without any ambient light at all.
【Customer Service】All product will be offered a 30 days’ free refund.12 months factory warranty and brand new replacement post within 24 hours If any defective item when receive .We provide Lifetime Support and 24 Hours Customer Service and Technical Support.
