Price: $9.89
(as of Mar 15, 2025 01:15:16 UTC – Details)
RSBYE Mini Electric Lighters,ARC Lighter Rechargeable Ultra Thin Windproof Lighter Double-Sided USB Lighter Touch Switch Lighter Plasma Flameless Lighter with LED Battery Indicator(Black)
🛠️【Smart Touch Switch】🔥 This lighter uses an electric spark to ignite, eliminating the need for fuel or harmful chemicals.Touch the switch to ignite and touch it again to stop ignition
🛠️【Double-Sided Ignition】🔥 Both sides can light through a heated tungsten wire. And soot cleaning is very convenient.Made with high-quality materials, the Mini Electric lighter is durable and can withstand everyday wear and tear.
🛠️【Flameless and Versatile】🔥 This lighter can be used for a variety of purposes, such as lighting candles, starting a fire, or igniting a gas stove. Its small size and easy-to-use design make it a versatile tool for everyday use.The electric lighter doesn’t need any gas or fuel. It’s safe and Flameless
🛠️【Rechargeable】🔥 The Mini Electric lighter is rechargeable via USB cable, making it a cost-effective and convenient alternative to disposable lighters. The USB lighter can be charged hundreds of times with a charging cable
