Price: $12.99 - $9.99
(as of Aug 18, 2024 09:45:15 UTC – Details)
RONXS Candle Lighter, Lighter Electric Lighter, Rechargeable USB Lighters Arc Lighter with LED Battery Display, Flameless Long Lighters for Candles Grill BBQ Camping (Black)
【LED Battery Display & Larger Capacity Lighter】This is the upgraded arc lighter which can display real-time battery volume. When 5 LED lights on the barrel turn on, it is fully charged. USB lighter can provide over 50*7 seconds on a full charge.
【Longer Flexible Neck & Lightweight】Our electric long matches for candles has a flexible neck (10cm or about 4 inches). It can easily rotate 360 degrees for different lighting needs. Lightweight size is suitable for daily indoor and outdoor use.
【Wind & Splash Proof】The wind and splash-proof design will protect the electric pulse from being blown out by strong wind or wet weather. RONXS lighter is a perfect tool for lighting under bad weather.No flame, no butane, no hassle. Compared with other lighters, the RONXS candle lighter will make less noise.
【What You Get】RONXS rechargeable matches, USB charging cable, a gift box, a user manual and 24h friendly services.
【Attention Please】Please fully charge it before first use to better protect the battery. After using the electric matches, you need to clean the position of the ARC pulse with a brush to remove flammable materials.
