Price: $21.49
(as of – Details)
Specification:Item Type: Portable Wifi
Material: ABS
Model: MF800-2
Color: White
Type: Plug In Card
Card Slot: Standard SIM Card
Battery Type: Supporting 2100mAh Lithium Battery (Included)
4G LTE Frequency Band: B1 B3 B5 B7 B8 B20 B38 B40
3G UMTS WCDMA: B1
Peak Rate: Download 150Mbps, Upload 50Mbps
WIFI: Support 802.11 b/g/n
Share: Up To 10 Users
Package List:1 x Portable Wifi1 x Matching Battery1 x Charging Cable1 x User Manual
Note:Please check whether there is a partition sticker at the battery interface before starting up.
ENHANCED SECURITY: The WiFi router utilizes advanced technology to ensure a stable and reliable signal so you can stay connected at all times. Your connection is secure from unauthorized access.
PORTABLE DESIGN: The WiFi router is designed with portability in mind. The router is compact enough to easily fit in your bag or pocket, perfect for traveling or working remotely.
HIGH SPEED WIFI: This portable WiFi router supports multiple users at the same time and allows you to enjoy up to lightning fast internet speeds. Perfect for home, travel and office use.
EASY SETUP: Setting up this WiFi router is a snap. Simply connect the router to your modem or existing network and you’re ready to go. No complicated installation or technical knowledge is required.
