Price: $229.99 - $89.99
(as of Mar 19, 2025 06:00:35 UTC – Details)
[Quality Night Vision and WDR Technology] The cabin cameras have an F1.8 aperture and 4 infrared lights. In addition to producing incredibly clear recordings, its image performance will be far superior to that of other dash cams at night. The two cameras also have the latest, most sensitive night vision image sensor integrated right into them, so they can capture stunning images even in pitch-black spaces at night.
[24H Parking Monitor] To leave it running while parked, you must get an ACC hardwire kit with low battery voltage sensing (not included). Dash cameras can be a well-hidden witness to the road in front of them thanks to their distinctive low-profile design. The two cameras may be turned 50 degrees left and right and 180 degrees forward and backward.
[Loop Recording and Emergency Accident Locks] To assure indefinite loop recording, the oldest unlocked footage will be automatically erased when the memory card reaches its maximum storage capacity. Supports class 10 or above micro-SD cards up to 512GB and loop recording for 1, 2, or 3 minutes. Once the built-in G-sensor senses a collision, the D30 dash cam will automatically lock the currently recording footage as evidence of an event. Loop Recording will not overwrite the locked files.
[Easy Installation with No Battery] With the help of the reference images in our user manual, this D30 dash camera is very simple to install and use. The accompanying suction mount is simple to install in a matter of seconds on your windshield. Add an SD card (not provided) and link to the power source. There is no battery included to prevent against mishaps from sun exposure, hot temperatures inside the automobile, or battery damage.
