Price: $66.69
(as of Mar 18, 2025 12:45:22 UTC – Details)
【SETUP ONLY TAKES 5 MINS】The projection screen can be set in about 5 minutes without any complicated tools.No screws, no strings,only several kinds of accessory, enough to fastly and firmly set it up.
【CONVENIENT TO CARRY】Rear projection screen with stand has weight of 6 lbs. You can hold it on one hand or put travel bags on your shoulders, easy to carry in anywhere you want and pack away. It easily stowed away in the CAR TRUNKS, Sedan included! That make it easy to travel along with for family trips, camping, or backyard movie night ect.
【DURABLE ALUMINIUM ALLOY FRAME】The foldable outdoor projector screen with unique base of the stands keep stable.Deeper plastic joints can be perfectly insert into aluminum poles with a tight fit to avoid loose.In addition,it comes with 4 stainless steel stakes,and it can be inserted in the hole of the bases when in the lawn,which can improve the stability.
【APPLICATION AREAS】 This projection screen can be used both indoors and outdoors. like camping, backyard movie, home theater, the large commercial activity center, performance entertainment center, even mini drive-in theater etc.
