Portable Power Station- 850W/ 600Wh Lumopal Solar Generator with 120V AC Pure Sine Wave Output (1000W peak) 100W USB-C PD, Backup Lithium Battery for Home Outdoor Camping RVs Trip Hunting Blackout
Price: $999.00 - $299.00
(as of Feb 14, 2025 16:15:22 UTC – Details)
850W Output Power (1000W Peak) & 600Wh High Capacity – Lum power 600 is equipped with a 600Wh high-quality battery pack and with 2 pure sine wave AC outlets to provide stable and safe power. Lumopal portable power generators also feature 2*DC ports, 1*PD 100W USB-C port, 3*USB-A ports and 1*car socket. Lum power 300 can power (up to) 9 devices simultaneously while recharging, supporting 850W output power (Peak 1000W).
Recharge to 80% in 2 Hours – Through the 140W charger equipped and 100W (Max) PD USB-C input port (USB-C cable not included),Lum power 600 portable power station can be fully charged to 80% within 2 hour. You can also charge the battery via a solar panel (PV 150W Max) and 12.6V car socket (solar panel not included) when camping/traveling. The portable solar generator allows charging power up to 350W.
Excellent Battery Management System – Equipped with the best BMS to protect the power station against short-circuit, over-current, over-voltage, over-load, over-heating, and low-voltage, and the wide operation temperature range of 5℉~131℉ for Lumopal electric generator ensures that Lum power 600 can give you a reliable and stable supply of electricity.
Portable and Lightweight -The well-designed structure of the Lumopal portable power supply squeezes every ounce of weight and size out of it while ensuring electrical safety. It is about 20% smaller than similar products, and the weight of Lum power 600 power station is only 14.22lb. Lum power series is always the perfect choice for camping, RVs, and home blackout.
What you get- 1* Lum Power Series (600Wh), 1* User Manual, 1* Charging Cable, 1* DC Adaptor(140W), 36-month Warranty, and Friendly Customer Service.
